Engine Bay restoration project.
Some recent picture of my winter project. Its loads of fun. I plan to swap every nut/bolt/seal/shield in the entire engine bay and have it looking as good under the hood as it looked on the outside.
I will keep updating as I make progress. So far I have dismantled everything as you can see and have swapped out all the nuts/bolts on the balance shaft section.
![](http://forums.rennlist.com/upload/engine_bayresize_001.jpg)
![](http://forums.rennlist.com/upload/engine_bayresize_002.jpg)
![](http://forums.rennlist.com/upload/engine_bayresize_003.jpg)
![](http://forums.rennlist.com/upload/engine_bayresize_004.jpg)
This pictures is all about the *****, lol.
![](http://forums.rennlist.com/upload/engine_bayresize_005.jpg)
Regards.
Raj
Regards.
Raj
Raj, my friend:
Is this your turbo replica? Man, I'm amazed at how much you care for your care. Your turbocharger appears to have a 4 in inlet. I installed a turbo with a 4 in. inlet, but have to sort some hurdles. Good look on your engine bay project.
Hi Raj: I am attemting something on a much smaller scale. I would like to clean and polish the exposed aluminum on the engine. Any suggestions? I tried a good metal polish to start with, but I wasn't real pleased with the results. Maybe I'm missing a step or two in the process for better results?
Thanks for the suggestions.
Bill
Bill
Bill, I have had great success using Simple Green. I use a toothbrush to scrub any additional dirt. I don't let it sit for too long and rinse it with water.
Raj
Raj
