Show me a photo of your engine bay!
Because mine is in not assembled. I could really use an example of where things should get mounted and how.
Also the second Image had the end to a cable and I am not sure where it is suposed to go
I did just recieve the Workshop maunals and the P.E.T
That cable plugs into a receptacle that sits against the firewall right ahead of the fusebox. It is usually covered with a plastic over. Look next to the brake booster and you will see it. If you have any other questions, feel free to post.
Raj
Raj
