Oil in Coolant Again!
I replaced the gasket 2 years ago at the oil cooler housing and thought it was residual stuff that would show up in the coolant reservoir since I couldn't get it perfectly clean...but it looks like it has reappeared. The car doesn't overheat, no froth in the oil (dipstick or under the oil fill cap). Just wondering:
Can I use the OPRV itself to align things? and should I use sealant with the gasket?
I hope it's not the headgasket!
Thanks - Bo
Thanks - Bo
Bo, it is quite easy to bind the OPRV when installing it. You can buy the alignment tool from Baum tools and its only $20 or so. I suggest buying the tool to align. I would start by doing all the O'rings and seals in the OPRV area and see what happens.
Raj
Raj
