Re-setting oil level warning light
Quick question. I have a 92 coupe. The oil level warning light is stuck on even though the level looks fine. It was fine untill I disconnected the battery for maintenance. Is there a reset procedure for the diagnostic computer? Not earth shattering but very annoying.
I have a test set up for 944's with the switch, pin and crocodile clip, but I don't know the procedure for a 968.
Thanks Richard
Thanks Richard
The oil level is on the max mark. Its very strange.
I wonder if a connection to the sensor wire has dropped off? it would be an amazing coincidence, as I haven't been near it.
Sam, I would start by checking the oil level sender connections. Usually when these things fail, they fail is max mode which for a warning light would be "on". It could be a coincidence but worth a try. The oil level sender unit is on the passenger side of the oil pan on the bottom in case you don't know.
Raj
Raj
