Recharge AC question.
Hey guys, where the LP side schrader valve? I found the high side, but I can’t seem to locate the LP side to do a recharge.
TIA
TIA
It is very poorly (MHO) located in the suction hose close to the compressor. Unfortunately it is positioned upside down which can allow water to wick its way past the threads of the dust cap. In the past I've had difficulty removing the caps due to rust and corrosion and/or found the service port rusted. Best wishes
Cliff
Cliff
Cliff
Cliff
I’ve never attempted to access it from above. Remember, IMO this is very poorly placed. Look in the parts catalog illustration 815-13 item #57. You’ll get an idea of it’s location.
Cliff
Cliff
Thx. Man is that a blow to morale. Totally physically incapable of doing that currently. Pissed I didn’t have it recharged when I last did my belts, even though it didn’t really need it then.
It requires access from below. If you don't have the batwing on, you can get at it below the driver's side headlight area. If you do have it on, you'll need to take it off. I believe the dryer is right there also. I had some pictures of me doing a charge on my 951, but can't easily find them.
dlearl476 (07-13-2024)
Y
So I was spending some quality time with the PET today while I watched the Goodwood FoS and I noticed something.
Part # 17 is listed as “-92” and part# 57 is listed as “93-“. Both are simply listed as “valve.” No other description given. Also looking at the drawing, the way the hose with 57 on it cut away like that looks like it could possibly be an alternate/superseded design? Just guessing here. I need to pull that cover off and see it there’s a valve under there. I looked the other day before I started the thread and couldn’t see it in there. #17 is listed as a 928 XXX XXX XX part. Hose #35 is also listed as a “-92” part.
I’m only second guessing this because last time the shop recharged my AC, they only charged me for the R-12. If they had to pull the pans to access the valves, I’m reasonably certain they would have charged me at least .5 for the labor. And lost half the pan hardware, as was their SOP.
It hasn’t for me since I bought the kit from Arnwerx. I use one of those magnetic cups when I disassemble and keep it in a safe place until I reassemble. Last time I had my belts done, I took it all off before I took it to the shop. Probably saved me a .5 hr of flat rate, too.
It’s Murphy’s law. If you have plenty of spares, you never lose any.
Please correct me, but that upper valve appears to be the suction side, between the evaporator and the compressor.
Pressure side of an A/C system goes to the condensor first to cool the compressed gas, then to the evap case/expansion valve to release the gas and absorb the interior heat, then suction to the compressor to start the process again.
If correct that the upper valve is between the evap and compressor, then the upper valve is where you'd connect a retail can of R-12/-134 for recharging.
I believe the difference between -92 and 93+ (parts 17 and 57) is an adapter valve for R-12 vs R-134a. My '92 was converted to R-134a with those (as was common practice in the 90s/00s). - GA
EDIT: as an aside, the fittings for high and low side are different (both R-12 and R-134a*); you cannot fit a low-side hose adapter to a high side fitting. Saves us from ourselves...so if your NAPA quick refill hose fits on there, it's the correct side.
*R-12 uses threaded fittings; the high side is 3/8 and the low side 7/16. R-134a uses quick-couplers, with the high side 16mm and the low side 13mm.
Cliff
On my 92 the low side port is down by the compressor, I chased a slow leak for years and got really familiar with it.
Tip: disconnect the charge hose with the compressor running so the pressure is lower and you lose less gas. Mind your fingers.
dlearl476 (07-16-2024)
Low side valve is located at the compressor/
