Clutch power spring
Hi all
can anyone confirm the use of power spring and where it mounts on 968. I can see it attaches to the pedal but cant work out the other end where the arm comes thru the spring
Peter
Peter
Wish I had a photo - the eye/clevis pin goes in the pedal. There is a metal plate with a hole in it - maybe an inch or two lower that where it is attached in the pedal? that’s where the other end goes through and you shove a cotter pin to keep it in there.
I will take a closer look this weekend ...however didnt see the tab for the shaft eye ...terrible spot to get in to but. All hunched up like a dog doing the business on a football.
