968 water pump kaput?
The heater core holds a bit so it is best to drive it twenty miles with the straight distilled water with the heat on then drain it warm.
Lindsey racing sells a drain extension that makes it a little cleaner job. https://www.lindseyracing.com/LR/Parts/944RADDRAIN.html
'universal coolant' isn't.
https://www.ecstuning.com/b-schwaben...l/003466sch01/
Figured this looked better than a traditional bleed...ever use one of these?
