VarioCam Tapping noise....HELP !!!
#91
That was quick. I'm glad you found the problem.
When I did my pan gasket, I didn't get a new alignment since it had recently been done. I just carefully realigned the caster blocks to my scribe marks, as you say. I was very observant for any changes in how the car handled and watched for any signs of increased tire wear. No problems ever came up and that was thousands of miles ago.
#93
This is a commen problem according to Hartech, the lower balance shaft vibration causes the pickup pipe to vibrate and resonate which leads to a fracture and eventual failure. I think I caught mine just in time as another mile or two and it would have dropped off completely.
I didn't replace the pipe I simply welded the pipe back together, and then sleeved it to reinforce the weak point where the pipe leaves the union.
Worst job of the day had to be undoing the engine mounts, talk about tight for space, got a case of the skinned knuckles from that one
When I get chance I'll put a picture up of the broken pipe, its something everyone should be aware of, I wonder how many people are driving around with the balance shafts out of time, I hardly noticed my lower one the vibration was so slight inside the car.
Mike
#96
I spoke to Hartech this morning and conveyed my thanks.
Raj,
I am so happy to sort this I cannot begin to explain, the car is now running spot on no ticking, rattles, vibrations or pressure problems.
I'm back on the Mobil1 0w40 which is what the car has always had and the oil pressure at temp is now pinned at 4.5 virtually all the time, only dropping down to a very steady 2.5 when stationary.
I'm still grinning with joy and I'm now confident to work on this beasty no matter what.
Next job is to change the tranmission oil and then get on with fitting my new shocks and struts which have been gathering dust for the last month.
Mike
Raj,
Mike
#97
It always nice to see a problem like this come to an end. Kudos to you for hanging in there and chipping away at potential suspects.
How did you do with the oil pan bolts? Also, how did the engine look on the inside?
Regards.
Raj
Regards.
Raj
#98
Oil pan bolts were fine I followed the procedure in the 944 manual although 2 stage torque setting was a bit of a drag for 4 & 8Nm ?? why they need this I do not know.
The engine is spotless inside with very little laquering and the cylinder bores were smooth with no visible scoring etc.. Given the time I didn't remove the Rod bearings to have a look, thought best not to over complicate things and end up with the car off the road any longer than neccessary.
I did find half a dozen cam teeth in the bottom, obviously from a previous set of cams.
Mike.
Mike.
#99
Very nice Mike! I have been following this thread off and on for a while as I have a 175k mile coupe and am glad to see everything worked out well. I hope mine does not experience the similar problem, but it is nice to know there is someone who has experience on this issue and has found it to be something other than the dreaded Variocam problem. If it comes up, nice to know someone can help with my home garage repair.
#102
Just a little bit Nick,
I think its only the fact I'd got the oil full to the max that it was managing to keep the oil going around, although at a reduced level on the top end.
I've been very lucky indeed
Mike
Mike
#104
Mike
Mike
Del, wakey wakey m8
I think one 968 in my garage is enough the wifes doing her nut as it is so best keep your motor down there matey, also you can't afford my labour rates
Mike
P.S. added some pics of the top end stripdown to my site tonight.
#105
Good job Mike!!!
Glad to hear that you were able to find the problem before it caused more problems - your persistance has paid huge dividends!
Interesting that the 180 degree out created the resonance to fracture the oil pickup tube.
Thanks for sharing and for being so persistant in determining the problem.
