front shock/strut mount rattle - upgrade time??
I thought it could be a ball-joint - but a shop that I trust says its the shock mount on drivers side.
I'm all about upgrades when service is needed. Do I put new Koni/Bilstein struts in? The offending strut looks to have a rotten/worn rubber boot at the top. Otherwise - nothing else is grossly worn.
Thoughts? Just the stock mount? Upgrade?
Am I hurting it driving right now?
cars is a 1994 968 coupe. No racing - but like to drive pretty hard in mountains. Pretty stock - does have an aftermarket upper strut mount brace.
front left strut mount.
I appreciate the replies/suggestions - anyone try that monoball mount they sell on paragon? I think the factory mounts are pretty rare and expensive.
I live in BFE - upstate SC. I think I'd prefer stuff that bolts in over conversions or welding, etc.
Just thinking if I have to have the struts pulled - I might as well upgrade. And yeah - paragon seems like a good source.
The upper mount is quite pricey but anything less will effect the ride quality. 'classic' parts come with 'classic' pricing. There is a thread with the bearing part number in this section if you want to go that route.
Did you change springs at the same time?
-Yogi
AKA 968 Novice
I appreciate all the replies in this thread.
Does anyone have experience w/ the aftermarket strut mounts? I'm trying to decide on that vs factory.
I have found the ADAC mount from the UK and that mount from Paragon. Any others out there?
[QUOTE=Yogii;15784274]For spirited street driving how is it compared to OEM Sachs? How often do you "adjust" them? Their adjustability is supposed to be one of their strong suits.
-Yogi
AKA 968 Novice[/QUOTE
I only use the car for street so have them set on the softer side. I think the are more firm than the OEM, I have stock springs.
-Yogi
Went the adj Konis route in completing the M030 setup on my S/CS. Awesome compliant ride. Current fast road setting of full hard -360 turn back. Perfect. I do on the odd occasion turn to full hard for a short drive to make use of full adjustable range. Definately notice the difference (good for track use not normal roads). Recommend the Konis. If your budget stretches check/upgrade all your bushes too.
