Started car, no instruments, tail lights or sunroof
Registered User
I started car after sitting for a month or so and have no instruments, tail lights or sunroof.
Lots of stuff comes up for 944 being some G2 relay that causes this exact scenario but I have no G2 relay.
Anyone can help??
Anyone can help??
Registered User
Ok Paul will try that. I saw those small cables yesterday when I was looking for a ground in that area. Do you know what the smaller cables are for?
Registered User
Originally Posted by thomasmryan
I usually give the battery an overnight trickle charge after a month so all the relays see 12+ volts during cranking .disconnect the negative first.
It's been on a battery tender the whole time.
Registered User
If the relay tests ok, try wiggling the key. Audi actually had a recall on the 91 and 92 ignition switches....but the dealer wouldn't comp my 90. Probably out of the same parts bin.
Do you know what relay I could test?
