964 Turbo Forum 1989-1994
964 Turbo 3.6 problem.
Old 02-16-2014, 04:53 PM
  #31
legacywr
legacywr's Avatar
I don't know what you mean?
Old 02-17-2014, 08:16 PM
  #32
rstarga
rstarga's Avatar
they are just subscribing to the thread. Have you had it diagnosed yet?
Old 02-18-2014, 04:15 PM
  #33
legacywr
legacywr's Avatar
Oh, I see
No I haven't, the weather never coincides with my auto electrician being free.
We are having real issues in the UK!
Old 03-08-2014, 11:56 AM
  #34
legacywr
legacywr's Avatar
Well, finally the weather picked up in the UK, and my auto electrician was free.
We have removed the immobiliser, checked the EZ, all seemed good, although we didn't have a great knowledge of it.
But, we only had 26 ohms where we should have 960 ohms on the crank sensor?
Old 03-08-2014, 04:25 PM
  #35
legacywr
legacywr's Avatar
Any advice?
Old 03-09-2014, 09:12 AM
  #36
Metal Guru
Metal Guru's Avatar
The manual says the value is 540-660 ohm (measured between the two poles of the flywheel sensor plug up on the EZ unit) so you should replace the sensor.
Old 03-11-2014, 06:17 PM
  #37
legacywr
legacywr's Avatar
Is this the crank sensor I need?
http://www.ebay.co.uk/itm/Porsche-96...item3f30790cc7
Old 03-12-2014, 09:32 AM
  #38
Metal Guru
Metal Guru's Avatar
Yes.
If you are doing the work yourself it's easier to buy a used sensor but risky in that it might not function or the connector may already be disintegrating.
You could buy a new sensor from the factory but the harness end will need to have a modern DIN standard plug fitted to it. Here it is in the Pelicanparts catalog:
http://www.pelicanparts.com/catalog/...pg3.htm#item15
You would also need to buy the electrical blades that go into the housing. The part number is 999-652-811-40 (3 required).
http://www.pelicanparts.com/catalog/...ELignt_pg2.htm
Quick Reply: 964 Turbo 3.6 problem.
