964 Turbo Forum 1989-1994
Best sounding exhaust?
Old 11-26-2013, 09:32 PM
  #31
nevillewakefield
nevillewakefield's Avatar
Default Mode
In my opinion if you can get him to make you one there's only one person who can make a really great equal length system and thats Bob Holcombe at Mode. Welds are an art form and mine even has heater boxes of sorts...
Old 11-26-2013, 10:16 PM
  #32
Bernard
Bernard's Avatar
Originally Posted by Evan@Fabspeed
This is actually something I am working to get soon!!
Sounds great, let us know once ready
Old 12-14-2013, 10:31 PM
  #33
mel_t_vin
mel_t_vin's Avatar
Originally Posted by Sharker
Mel, the work was done before I got the car so I can't be sure. I am installing a lift in my garage, and it is almost ready to go. Will post underbelly pics when I have it working.
Jeff, did you ever get that lift installed?
Old 12-15-2013, 09:30 AM
  #34
Sharker
Sharker's Avatar
Yep, just before a snowstorm.. only got the crappy pic from the underside.. need to spend some time under there cleaning up, but been stupid busy lately
Old 12-15-2013, 05:36 PM
  #35
mel_t_vin
mel_t_vin's Avatar
Yep, just before a snowstorm...
Sweet!
So, I see you're running a cat bypass pipe. Does that pipe run to a muffler, or, does it run to an exhaust "tip" and dump directly to atmosphere?
Old 12-15-2013, 05:51 PM
  #36
Sharker
Sharker's Avatar
It is a bad pic, but it goes to a muffler.. My exhaust is loud (esp under WOT) but not obnoxious, in my opinion
Old 12-16-2013, 01:59 AM
  #37
mel_t_vin
mel_t_vin's Avatar
Jeff, that actually looks like the factory muffler. Though, from what I understand, that's not all bad.
I've seen a 965 muffler cut open, with its top skin removed, and it appeared to have a very open, free-flowing, design. Obviously, one thing the factory improved from the 930...
Old 12-31-2013, 01:10 AM
  #38
niche
niche's Avatar
My turbo 993 is more like a 965 as it is a 95 Ruf Btr. I was bummed about how quiet it was. Today I removed the muffler for a bypass and that was all it needed. Didn't mess with cats or anything else. Sounds great. And a very cheap mod.
Old 12-31-2013, 02:22 AM
  #39
mel_t_vin
mel_t_vin's Avatar
Javier, your 993 has two mufflers, correct? One for each cylinder bank?
So, you essentially replaced each muffler with a simple straight pipe?
Would you happen to have a sound bite of the before/after?
Old 12-31-2013, 02:26 AM
  #40
niche
niche's Avatar
My set up is pretty close to the 965. The Ruf BTR is a single turbo 993. Yes, I took out muffler and replacedwith a pipe. I may be able to put a clip together. I have a crude one of stock set up.
Old 12-31-2013, 03:30 AM
  #41
keynes
keynes's Avatar
The turbo is on one side of the engine. Not in the middle. How can you ever have an "equal length" exhaust without making the closer pipes longer (inducing lag)? The difference in exhaust travel is inches. Does it matter enough to buy one of these?
Keynes
Old 12-31-2013, 10:04 AM
  #42
Metal Guru
Metal Guru's Avatar
Keynes
If you look at the RarlyL8 headers, the two banks are offset to the left side. They are not advertised as "equal length" but rather "near equal length". Good enough for me since they are good for a 15 hp bump. They are on my list of future mods
http://rarelyl8.com/930-headers.html
Old 12-31-2013, 12:59 PM
  #43
MeanMachine
MeanMachine's Avatar
I wish someone would make proper set of headers for a 3.6
Old 12-31-2013, 09:45 PM
  #44
niche
niche's Avatar
Just took the after, today. Kinda crude from a camera phone, but you get the idea.
Before:
After:
Old 01-01-2014, 02:23 AM
  #45
mel_t_vin
mel_t_vin's Avatar
Not so quiet anymore, is it.
I completely missed that your car was a '95, narrow-body, 993...I thought it was a Ruf-massaged, twin-turbo, with AWD.
So, your car is a 3.6L, single-turbo, with RWD? Are all 993-based Ruf BTRs built on a narrow body with single turbo? What turbo did Ruf use in your build? Did Ruf also massage your suspension?
Have you ever timed a run from 100-160 kph or 100-200 kph?
Quick Reply: Best sounding exhaust?
