CCW classic pic request
No - the front wheels for a 964 or 965 Turbo are 8" front ET 52 and in the rear Speedline wheels are 10" ET 61 the RH wheels are 10's but are ET 54. The 911 and 930 cars have different offset allowing very deep rear lips, yours can be built with 1.75 or 2.25" depending on whose center you are using. -- unless you change your rear trailing arms to narrow body cars then you can run deeper rear outer rims.
I have been building 10.5 or 10.75" rear rims which is the widest that will fit - in my opinion. It is 3/4" wider than stock. jdorociak@gmail.com jim
These centers are known to crack so be very careful and inspect often. I was racing in Vegas a few years back with these wheels and noticed the majority of the spokes had hairline cracks after a few sessions. I promptly decided to switch to Fikse thinking about what a disaster it would have been if my front wheel broke at 145 mph on the banking.......
