964 Turbo Forum 1989-1994
Replacing Stone Guards
Old 08-20-2009, 11:17 PM
964TURBOCHAS
964TURBOCHAS's Avatar
Default Replacing Stone Guards
I going to replace my stone guards this weekend.
My question is how do you remove the lower trim pieces in order to get to the bottom edge of the stone guards? I was wondering if there was a DIY write up on it.
Chas
Old 08-20-2009, 11:29 PM
dholling13
dholling13's Avatar
i posted a very in depth article a few years ago on this.
Old 08-21-2009, 03:08 AM
WPOZZZ
WPOZZZ's Avatar
There's about 4 Phillips head screws that need to be taken off. After that there are @ 4 clips that hold it in on the rocker panel. You will need to pop these off. While you're at it, get a few spare clips from the dealer just in case you break one. The 965 has different rocker clips than the 964.
Old 08-21-2009, 09:43 AM
964TURBOCHAS
WPOZZZ
do u need to remove the rear wheels?
964TURBOCHAS
I did a search Drew but couldnt find anything. .......do you have a link?
Old 08-21-2009, 05:18 PM
WPOZZZ
WPOZZZ's Avatar
Originally Posted by 964TURBOCHAS
WPOZZZ
The wheels stay on the car.
Old 08-21-2009, 05:24 PM
964TURBOCHAS
man I started this.......what a freeking mess!!
Mine have been on so long that they are coming off in 1/8" x 1/8" pcs........I cannot get the guard to just peel off using heat. I even tried a heat gun................
Old 08-21-2009, 06:46 PM
Boeing 717
Registered User
Boeing 717's Avatar
Yea its no fun. There is no easy way. Goo Gone helps but only a little.
Old 08-21-2009, 07:42 PM
964TURBOCHAS
Im thinking of sanding them and then repainting the rear quarters...........
Old 09-02-2009, 01:02 AM
RFMASSA
RFMASSA's Avatar
Does anyone know if the stone guards on a 993 are typically clear or painted body color? I have an arctic silver 993 and want to replace them. I only can find clear, but I have noticed OEM guards from Porche are available in Polar Silver and some other colors, but have not found arctic silver.
-Thanks.
Quick Reply: Replacing Stone Guards
