964 Turbo Forum 1989-1994
who is running a JIC cross setup and
Old 06-07-2009, 10:52 AM
tasracer
tasracer's Avatar
Default who is running a JIC cross setup and
what do u have and what is your baseline setting
looking for a baseline ride hieght,rake and compression and rebound settings for track use
tracking it next w/e and need to know where to start
Old 06-07-2009, 07:14 PM
911addict
911addict's Avatar
Pretty sure dholling13 knows this setup. Or try a search...
Old 06-14-2009, 11:17 AM
Turbohead
Turbohead's Avatar
I have this set up.
I set my rears at 6 from soft and fronts at 5 from soft for street.
For track 10 R and 12 F if the track is bumpy Imight back of a little. for smoth sweepers i tighten up.
I have 10 -14 KG program springs, Spring plates, monoballs, and sways,Set to RS height specs.
Hope that helps.
Elliot
Old 06-14-2009, 11:30 AM
tasracer
tasracer's Avatar
yes this does help as i was running at track 5 off R and 4 off F on 9-12KG at the track
guess i need to try more shock and try the front stiffer than rear... also it appears u r running more rake than i am... what r the rs ride hieght specs and what about tow and caster/camber
Old 06-14-2009, 11:31 AM
tasracer
tasracer's Avatar
where did u get the sways at?
Old 06-14-2009, 03:31 PM
dholling13
dholling13's Avatar
Did you get my pm?
Old 06-15-2009, 11:14 PM
Turbohead
Turbohead's Avatar
I'll have to look up the alignment specs and get back to you. You cannot lower the car too much since you will get a lot of bump steer. Mine seems to be just right I have a good tech. set to ROW RS .
I got the adjustable sways from TRG.
You need to special rear drop links for them.
Car is very capable and neutral. (GT3 killer)
Elliot
Old 06-16-2009, 11:27 AM
tasracer
tasracer's Avatar
ur front looks lower than mine... my "guy" is good but these are sunique cars that need special setups and his general knowledge my not be as applicable...
waiting to get specs from u guys then in for an aliengment and cornerbalance
Quick Reply: who is running a JIC cross setup and
