hot start question
hot start question
From cold my car fires up immediately with smooth idle
From hot i have to press accelerator and then it idles rough for a short while.
Is it the warm up regulator or what else?
Rennlist Lifetime Member
Start by checking the rest pressure. Normally hot start issues are caused by a drop in pressure after shut off. The accumlator will take care of that and or the check valve at the pump. The only way to 100% know is to hook up the pressure gauges and see what the pressures are when you shut the key off.
Is this part at all universal? I.e. is it common to all CIS Porsches? Could I get one at my VW parts dept asking for an accumulator for an '82 Rabbit? In my experience with Audi it was common for DIY'ers to dodge the "Audi Tax" with VW intercompatible parts. It'd be nice to have a silver lining to the CIS if any parts were intercompatible with the plethora of other '70s and '80s Audis, VWs, Mercedes CIS systems. I'm not being cheap, I simply don't have a bottomless slushfund for my car like some guys.
Unfortunately I can't find any apparent cross-compatability to more common makes.
Lowest price I've found so far...
http://www.importpartsspec.com/cart/show/item/233150
AG02 you got a damn good price at $215. Retail is $394 and prices are all over the place due to limited availability.
This brings up a good point on fuel systems. When should we change our filters, accumulaters, and clean the WUR?
p.s. My silver child's doctor has my CC info on file
I want to order from there now! Sunset Porsche does however sell new parts lower than some of dismantlers sell used parts.
I took into context that my local independent wanted retail and a week to get it. Parts Heaven had it for ~$250 and they're semi-local to me. There were few online sources that carry it, and many of them were in the $250-300 range. The $150 was the only price I found lower than yours and I've grown skeptical of the lowest price source as they usually take their sweet time to send you the wrong part, only it was mis-addressed, and broken when you get it and nobody will reply to your RMA requests.
Bitter? Me?
Bitter? Me?
Bitter? Me?
Bitter? Me?
Here are some more Bosch part numbers if interested for 91-92t.
0 280 140 204 Auxiliary Air Valve
0 438 120 205 Air Flow Sensor
0 280 170 400 Cold Start Valve
0 438 170 031 Fuel Accumulator
0 438 100 145 Fuel Distributor
0 986 438 145 Fuel Distributor
0 280 150 300 Frequency Valve
0 280 160 302 Vacuum Limiter
0 437 502 017 Injection Valve
0 280 800 072 ECU
0 280 142 102 Overrun Cut-Off Valve
0 280 120 107 Throttle Switch
0 261 220 002 Temperature Sensor - Intake Air
0 280 130 026 Temperature Sensor - Oil
0 438 140 160 Warm-Up Regulator
0 280 800 072 ECU
0, 017, 0280140204, 0280160302, 0438100145, 0438140160, 0438170031, 140, 204, 280, 437, 502, bosch, cross, flow, operating, part, pressure, rest
