964 Turbo Forum 1989-1994
damaged speedline 3.6
Old 09-01-2006, 07:03 PM
summax
summax's Avatar
Default damaged speedline 3.6
Hello evryone.
I just purchased a complete set of OEM Speedline wheels, but some wheel either broken studs or mickey mouse studs and nuts. I know i should ask question before buying stuffs.. anyway, any of you have a broken, damaged wheel and want to get rid of at the sametime help me out? or perhaps you can give me advice where to get them.
Thank you very much.
i can be contacted at dp@selectgp.com
Old 09-02-2006, 03:31 AM
Kevin
Kevin's Avatar
Were these the ebay wheels that sold last week
Old 09-02-2006, 11:35 AM
Flachbau
Flachbau's Avatar
You cannot purchase the original bolts from Speedline. Given your description I would suggest replacing all of the bolts in each wheel. I believe the tightening torque is 22 ft.lbs. You also might need to pull them apart and check the gaskets, they should probably be replaced as well. If you have not done the gaskets before you might want to have a professional do them for you otherwise you may wind up with a leak and a forever flattening tire that cannot be fixed unless you do the gasket again.
Here is a source for premium bolts.
http://www.titanium-touch.de/titaniumtouche/index.htm
Old 09-02-2006, 02:45 PM
VinnyC
VinnyC's Avatar
Flachbau - That looks like a great resource for a hard to find item. Thanks for the link!!
Old 09-02-2006, 07:19 PM
Flachbau
Flachbau's Avatar
For super bling maybe some gold plated rim bolts on the black rims on your TT .... probably good for a few extra visual HP
Old 09-03-2006, 04:49 AM
nathanUK '81 930 G50
nathanUK '81 930 G50's Avatar
I remember seeing gold parts on cars in Puerto Banus on the Costa Del Sol when I was a kid. The 80's I guess.
Old 09-03-2006, 06:57 AM
JamesE
RIP
JamesE's Avatar
I got samples of these bolts sent to me. The problem is that the style most like the speedline bolt is not made long enough i.e. 40mm. You have to use the top bolt on their website (i.e. the 40mm one), which looks poor IMO. I did speak to the owner and ask how many bolts i'd have to order for him to make the bolt i wanted but in 40mm rather than 30mm, and it was something like 500k units...
Old 09-03-2006, 09:09 PM
summax
summax's Avatar
Hi again
Thank you for that link, Flacbau.
Yes, Kevin I bought that wheels on Ebay last week.
Anyone else have ugly, broken, bented Speedline wheel out there please chim in. I'd like to buy it from you.
Thank you
Old 09-04-2006, 01:53 AM
Kevin
Kevin's Avatar
I was looking at those rims myself.. How many studs are broken?
Old 09-04-2006, 10:44 PM
summax
summax's Avatar
3 studs and he used Jb weld to hold them in place.
Old 09-05-2006, 11:11 AM
cobalt
cobalt's Avatar
Received 2,206 Likes on 1,316 Posts
Sorry to here the wheels are a problem.
I spoke to the owner and he was willing to sell me the wheels for less on the side but every time I spoke to him there were more and more issues. His ad was a bit misleading. I believe one wheel is original factory condition while the other 3 had been taken apart and refinished You could see in the pictures that the air valve was not positioned as it normally should be and I was concerned that they were not sealed properly. I would plan on buying new bolts and seals for those 3 wheels and have them reworked before you mount the tires.
Old 09-05-2006, 03:39 PM
summax
summax's Avatar
Hi Anthony
Yes, that's what i will plan to do Or I may be ask the seller if I could return the wheels.
Old 09-05-2006, 10:25 PM
VinnyC
VinnyC's Avatar
Careful, I was offered a "Second Chance" three times on those wheels when I was outbid. Scam artists love that trick.
Old 09-06-2006, 10:46 AM
cobalt
cobalt's Avatar
Originally Posted by summax
Hi Anthony
His ad did say money back if not satisfied. You may just ask for a reduction in price. Figure out what it will cost you to bring them up to speed and knock that off the price. Otherwise I would bring it to Ebay's attention if he is uncooperative. I have gone through issues like this before. Although it took a while I ended up with a refund in each case.
I don't think he will give you a hard time he appeared to be reasonable on the phone.
Overall the wheels looked good I just get nervous trusting my car to a 3 piece wheel that has broken bolts or resealed by someone I do not know.
Old 09-15-2006, 03:02 AM
jim dorociak
jim dorociak's Avatar
I noticed the post as I am embarking on refinishing a set of OZ racing TT 3 piece wheels.
ebay item 4625130286 bolts for sale for split rims if you can not find the listing try calling Peter on 01253347984 or his website is www.pwsukdirect.com or pwsuk@globalnet.co.uk for email
goodluck I am having trouble finding the tools needed to loosen the bolts and nuts, but it looks like I may have found a source in Germany info@titanium-touch.com anyway it should be fun. Jim
Quick Reply: damaged speedline 3.6
