Intercooler reconnect boost sensors which wires?
Just making sure I hooked up the correct wires to the boost gauge sensor and to the overboost cut off switch. I have the green and brown striped wire going to the boost gauge switch and the yellowish/tan wire going to the overboost cut off switch. Is this correct? Maybe someone could post a photo for future reference to this question on the board.
TIA
Mark
TIA
Mark
TIA
Mark
TIA
Mark
I have forgotten to connect the pressure switch a few times, it's easy to tell, the car starts but stops after a second or so.
Originally Posted by Staffan
Yes I believe this is correct.
There is a picture here on Cobalts car.
https://rennlist.com/forums/964-turbo-forum/108037-billet-bypass-valve.html
https://rennlist.com/forums/showthread.php?t=108037
Hmmm? Thanks ... but difficult to see exactly. Next time anyone has a chance to pop their rear lid and have a quick look I would appreciate it ..... is anyone out there??? Staffan and I are like lone rangers at the moment ...
Originally Posted by JBH
Gladly, but could you please tell me which is the boost gauge sensor and which is the overboost cut off switch
Nevermind...here's a pic of mine
![](http://forums.rennlist.com/upload/boost_gauge_copy1.jpg)
Trying to reconnect my wiring...
So the other wire coming out of that loom goes to the overboost switch. Then does a wire go from the other overboost switch pole to the intercooler ground?
TIA.
RT
TIA.
RT
I just went out and looked for you.
Tan-overboost switch. Make sure the connection is tight, you don't want that one working its way loose.
Brown and Green-Boost gauge sending unit (the big orange thing).
The other wire to the intercooler ground.
Bill
Bill
Just to make sure we are talking the same colors...
