964 Turbo Forum 1989-1994
Sponsored by: HBI Auto
C2 Turbo Question
Old Jan 10, 2006 | 08:42 PM
JRRSA's Avatar
JRRSA
Default C2 Turbo Question
I am looking for a little feedback on a C2 Turbo that I am considering for purchase.
I am strongly considering a 30K mile 92 C2 Turbo. It is a very clean all original car. The complete 30K service was completed last year. The car has been stored for about a year with less than 100 miles accumulated during that time.
I was sold on the car until I looked below the engine and noticed what I would describe as a significant oil leak. The owner says that it's the valve cover seals. Could this be related to the fact that it has been sitting? Is this a major problem / area of concern with these cars?
If I pursue the car I will most definitely have a PPI performed, however, if this oil leaking problem coupled with the fact that it has been sitting are signs of major problems then I may have to keep looking.
Thanks for the help...
Old Jan 10, 2006 | 09:41 PM
Kevin's Avatar
Kevin
JRoss, I'll list a few oil leakers
Valve cover gaskets
Oil drain tubes
Cam boxes
Cam box to Cam housing
Chain tensioner oil lines
Turbocharger
Front crank seal
Rear main seal
This past summer I purchased a clean '92.. The oring between the chain box and cam housing is weeping oil.. It drip one or two drips a night.. I'll fix it one day..
I would not walk away from a clean un-molested car just for a few leaks.. They can be fixed a little at a time, or when you drop the engine for the clutch. Get the PPI done and see what you have found.. But again I'd take the value of clean car over a few orings and gaskets.. Turbocharged engines generate alot of heat. And you will be amazed at how many cars have some sort of leak..
Old Jan 10, 2006 | 10:21 PM
SonnyV's Avatar
SonnyV
Lifetime Member
I second Kevin's comments.
My car is very clean and run great but it does have some wetness from the valve covers on the left side too. I will fix it when it is time for another major service. It does drop about 1 or 2 drops a week, which is very little, and only when driven.
Regards,
Sonny
Old Jan 10, 2006 | 10:38 PM
JRRSA's Avatar
JRRSA
Sonny and Kevin,
Thank you for your very helpful comments.
This car seemed to be dropping quite a bit more than a couple drops. There were several drops hanging off ready to fall when I looked below - it definitely was significant. There was a piece of cardboard under the car that was throughly soaked. Having said that, as mentioned before, the car was extremely clean, all original, 100% stock with the protective coating still on the undercarriage. With a days cleaning and waxing, it would most definitely be a concourse candidate.
Old Jan 11, 2006 | 09:26 AM
oscar94's Avatar
oscar94
If you don't buy it...how about posting its location for the rest of us in the market.
Old Jan 11, 2006 | 10:24 AM
last toy's Avatar
last toy
Jross,
This sounds like the 92 Turbo with 30 K miles offered by performance Auto in St James, NY. It is Guards Red and prestine looking for $46,000. I may be interested as well but undecided. There are a lot of mods I can do with my C4. This one does look enticing.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Jan 11, 2006 | 01:12 PM
Staffan's Avatar
Staffan
Originally Posted by JRossRSA
Sonny and Kevin,
If the oil is from a leaking valve cover I wouldn't worry to much about it.
However, oil leaks can be hard to trace, not allways that easy to tell where the oil originates from. If it only was a valve cover gasket, why is't it fixed, simple job ?
Personally I would have a leakdown test done and then take it for a hard drive and check underneath for oil leaks again.
Old Jan 11, 2006 | 02:57 PM
JRRSA's Avatar
JRRSA
Thanks for the input on the leak.
It's not the car pictured above. As I posted earlier, I called on that car and found that they didn't have the original parts - which may not be a big deal for some.
Old Jan 11, 2006 | 06:11 PM
Staffan's Avatar
Staffan
You mean like the wheels, or are there other things that are not stock?
Old Jan 11, 2006 | 08:43 PM
JRRSA's Avatar
JRRSA
The person I talked to mentioned both wheels and exhaust, which I would assume could mean the cat as well. This could cause a problem for those with emissions inspections.
