964 Turbo Forum 1989-1994
Diet...
Old 09-18-2005, 10:05 AM
James.E
James.E's Avatar
Default Diet...
Quite lardy these turbo's, and that just wont do.
Out with:
Old 09-18-2005, 10:07 AM
James.E
James.E's Avatar
...and sound proofing:
Old 09-18-2005, 10:10 AM
James.E
James.E's Avatar
In with:
Old 09-18-2005, 10:12 AM
James.E
James.E's Avatar
and:
Old 09-18-2005, 10:15 AM
James.E
James.E's Avatar
So basically gone for full RS interior and 6 pt harnesses. Old rear seat mountings have be drilled out and removed, and new harness mounting points welded in....
Old 09-18-2005, 10:32 AM
Geoffrey
Geoffrey's Avatar
James,
For sure this stuff weighs a ton. When I stripped my C2, the wiring harness alone weighed 55lbs, the HVAC system 30lbs, etc. I did put my bare chassis with solid roof and turbo flares, seam welding, and with cage on my scales prior to powercoating and it weighed 571lbs which I thought was pretty light.
Old 09-18-2005, 11:59 AM
Sameer
Sameer's Avatar
James,
did you weigh all that stuff you took out?
Old 09-18-2005, 12:02 PM
James.E
James.E's Avatar
Geoffrey, it is amazing where the weight comes from. I'd be very happy if I could get close to 1300kg, but that might be a push, as i'm keeping air con, adding second oil cooler etc. I will replace the rear screen with the RS lightwieght item which has to be worth a few KG. The BBS mags I run have saved 20KG. Next year, i'm thinking about replacing as many body pannels as possible with carbon fibre.
Old 09-18-2005, 06:10 PM
Miles965uk
Miles965uk's Avatar
Damm theres alot of extra padding in our motors... one cheap way of making things move faster! We should still meet up James when you get it back give me a shout - cant wait to see it
Miles
Old 09-18-2005, 06:22 PM
tasracer
tasracer's Avatar
you have inspired me
time to redo the interior!!!!
Old 09-18-2005, 06:29 PM
DrJupeman
DrJupeman's Avatar
The sick irony is that I have added 180 lbs of lead to my car to "make weight" for PCA C Class. I have to meet the Porsche book weight of 3274#. My car, without any lightening other than seats (offset by full cage?) was way under that (about 180#... ).
Old 09-19-2005, 02:51 AM
James.E
James.E's Avatar
Sameer, the car weighed 1430kg before (which is down 40kg on stock wieght due to headers, spoiler, clutch being changed). I'll weight again afterwards.
My engine has also been completely stripped down, but that will be a new thread in due course...
Old 09-19-2005, 03:51 AM
Sameer
Sameer's Avatar
Will have to weigh my car too.
Old 09-19-2005, 09:52 AM
Sameer
Sameer's Avatar
James,
where are you buying your rear RS windscreen from? I want to get one too.
Old 09-19-2005, 04:29 PM
James.E
James.E's Avatar
Ok, just decided to ditch the Air Con, never worked properly any way. It'll also make way for big secondary oil cooler....
Not sure where the rear screen is coming from yet.
Quick Reply: Diet...
