964 Turbo Forum 1989-1994
Diet...
Old 09-19-2005, 11:02 PM
tasracer
tasracer's Avatar
just ordered my very own rs carpet set!!!
game on!!!
Old 09-20-2005, 01:21 AM
Sameer
Sameer's Avatar
tasracer,
where you buy your RS carpet from? I plan to buy th RS rear windscreen but dont know where to source from.
Old 09-20-2005, 10:44 AM
tasracer
tasracer's Avatar
carpet and doors appbiz.com
Old 09-20-2005, 01:06 PM
Sameer
Sameer's Avatar
thanks
Old 09-21-2005, 04:10 AM
Sameer
Sameer's Avatar
tasracer,
Cant seem to find any windscreen on their website.
Old 09-21-2005, 09:03 AM
Vince5
Vince5's Avatar
Guys I am on the same path
Here is what was removed
Sport seats replaces by race backets
Isolation material removed, RS carpets (partly)
AC and all the plumbing + compressor support
Radio
Airbags
Air pump and plumbing
Muffler
I now have a full roll cage and a 6 point harness + bigger front brakes.
Last check the car came out at 1409KG with me (70KG) and just under halt a tank. Empty I am at 1300KGs
Still to do
Rear spoiler
Doors
LWFW
Windows (RS or Lexan)
But unless the PCSRacing rules change I can only remove another 50KGs before my weight / HP ratio goes down to much. I will keep focusing on taking out weight on the rear wheels.
Old 09-21-2005, 11:14 AM
jeff91C2T
jeff91C2T's Avatar
FYI...I switched to the 3.8 wing and lost 15 lbs over the stock lid.
Old 09-21-2005, 11:34 AM
Geoffrey
Geoffrey's Avatar
I am on target to end up in the 930kg range with my racecar. This includes a 6spd, centerlocks, RSR brakes, and all of the safety items.
James, if you need the part numbers for the secondary oil cooler and lines, let me know, I have them.
Old 09-21-2005, 11:38 AM
Vince5
Vince5's Avatar
How does cooling work with the 3,8 wing ? Did you notice the intercooler worked lke before ? Thanks !
Old 09-21-2005, 11:49 AM
Geoffrey
Geoffrey's Avatar
There are two different 3.8 wing configurations, one with the RSR cooling vents and one with a larger number of vents for turbo applications. Not all venders sell both.
Old 09-21-2005, 12:11 PM
Vince5
Vince5's Avatar
Good info Any idea which make sell the turbo "version" ? My shop usualy uses cargraphics so that's what they will propose by default !
Old 09-21-2005, 12:40 PM
Sameer
Sameer's Avatar
You can try Getty Racing, MaShaw or GT Racing
Old 09-21-2005, 12:44 PM
Vince5
Vince5's Avatar
Thanks guys !
Old 09-21-2005, 12:53 PM
Miles965uk
Miles965uk's Avatar
or use the gt2 wing.... should run cooler with the air intakes...
Old 09-21-2005, 04:26 PM
jeff91C2T
jeff91C2T's Avatar
Vince, I'm running the 3.8 RSR (w/ the extra vents). An item to keep in mind is that these aftermarket wings (mashaw in my case) have plenty of vents to get air through, but what they don't have is the factory ducting to channel the air through the intercooler. So to answer your question, I wouldn't expect it to cool as well since I'm not ducting the air through as effectively as the factory tail. For what I'm doing w/ my car this has been acceptable. Getting the duct work off my old tail and seeing if it works w/ the new lid would be the right thing to do though...
Quick Reply: Diet...
