964 Turbo Forum 1989-1994
Chassic Dyno result
Old 06-30-2005, 07:58 PM
summax
summax's Avatar
Default Chassic Dyno result
Hello everyone
Dynoed my car (1994 3.6 Turbo) earlier today. Please see the attachment.
Mods include: new K27HF"S", BB header w/ heat exchanger, 1 Bar spring, Catless.
Let me know what you think.
Thanks for reading my post.
Regards
Old 06-30-2005, 08:11 PM
tasracer
tasracer's Avatar
stock turbo same mods 374hp
tasracer
tasracer's Avatar
oh at 1.1 boost
Old 06-30-2005, 09:39 PM
PorschePhD
Rennlist Lifetime Member
PorschePhD's Avatar
That is about 415 at the crank not to bad. Did you do a run before hand. Nice usable curve as well.
Tasracer, are you quoting wheel or crank. Because at 374RWHP that is about is about 440HP. That is not possible at 1.1 bar.
Old 06-30-2005, 10:00 PM
38D
38D's Avatar
Exactly. A nice curve gives a car that's more driveable. It's not just about peak power!
Old 06-30-2005, 10:44 PM
Ruf-Dan-Ruf
Ruf-Dan-Ruf's Avatar
I have 383 RWL HP at 1 bar boost, so it is possible on a single turbo 3.6.
Old 06-30-2005, 11:40 PM
JBH
JBH's Avatar
Look how flat that torque curve is. That's what you want!
Old 07-01-2005, 12:24 AM
Kevin
Kevin's Avatar
Very Nice... 350 ft lbs at 3500 RPM
Old 07-01-2005, 09:49 AM
38D
38D's Avatar
Yes, but yours is s RUF, no? In think Stephen is saying that the stock engine can't do that much rwhp with just a boost increase.
Old 07-01-2005, 10:08 AM
PorschePhD
PorschePhD's Avatar
Correct, the comparison was a stock turbo. I would hope that a RUF would do those numbers. We achieve 420WRHP (still CIS) with our packages. That is with internal mods.
Old 07-01-2005, 10:16 AM
tasracer
tasracer's Avatar
rwhp not crank got the sheets
Old 07-01-2005, 10:19 AM
PorschePhD
PorschePhD's Avatar
Please post them along with the boost graph so that others can compare. It is always good to show like setups.
Old 07-01-2005, 11:18 AM
cobalt
cobalt's Avatar
Received 2,170 Likes on 1,299 Posts
Looks good but why does the torque drop off so abruptly? Mine begins to drop off at 5400 rpm but is still at 280 lb/ft at redline. This was before I fixed the intake leak which I believe has carried the torque even higher towards the redline.
Old 07-01-2005, 11:22 AM
Sameer
Sameer's Avatar
summax,
thats some good numbers with not that many mods, way to go!
Old 07-01-2005, 11:34 AM
PorschePhD
PorschePhD's Avatar
Looks like someone let off the throttle. It kills the chart when you do that.
Quick Reply: Chassic Dyno result
