Brake rotors
No affiliation but there are 91-92 rotors front and rear on ebay new in box starting price $250 per set.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
I was also curious how much are the 94 rotors selling for I found them for $179 ea is this a good price? I don't need them for my tubo but I found out they are the same part for the GTS.
Lifetime Member
Lifetime Member
Anthony,
That is good price, wonder how high it will go. These are about $212 each from places like Vertex. I am looking for a hold set 2 front and 2 rears, but i don't like to buy from ebay. I will probably go with Sunset Porsche at cost + 15% when I am ready.
The 3.6 turbo rotors at $179 each is about normal price. They will fit 91-92' cars but because the calipers, front, on 91-92' are a little smaller you will have a small area that is not sweep by the pads on the side near the hub I believe.
Regards,
Sonny
Regards,
Sonny
Thanks,
Buying parts on Ebay can be risky. Although I have found 99-100 buys to be a favorable experience and a bargain. The one bad experience iA had was resolved and my money refunded in full. The seller seams to have a good record and if the price is right you may be able to get a really good deal.
I am looking sources for front calpiers. I track my car and the cross drilled rotors crack long before they wear.
Cobalt - Ist what is your souce for $179 & is that price delivered? The best I can find is $187 delivered and with tax.
Sonny- Do you mean the 3.3 turbo rotors fit the 3.6 ? I measured by 3.6 rotors which are 320mmx32mm. Do you know what the 3.3 rotors measure?
Both Sonny and Cobalt - What 928 rotors fit? Do you have a part #. Thanks
Earl
Earl
Lifetime Member
Lifetime Member
Earl
Earl
It is the other way around. 3.6turbo's rotors (front) will fit 3.3 C2turbo (front). They are both the same size. I will have to confirm tomorrow when I look it up tonight. 3.6Turbo's front calipers are larger than 3.3 C2turbo's front calipers.
Sonny
Earl
Earl
If you are interested in the solid rotors i have a set I am selling. PM me if you are interested.
I figured that was you, I was going to congratulate you before but got busy. Great price for sure.
Anthony,
Thanks! Btw did i need them,no but did i want them,you bet.The rotors were almost half price from the cheapest place i could find ( strasse $240 + S&H ) so heck why not save them for the future.
