964 Turbo Forum 1989-1994
New to me Forest Green 964T
Old 01-31-2024, 12:07 PM
  #31
bweSteve
bweSteve's Avatar
Received 1,054 Likes on 668 Posts
Oh, & I should also mention,... that the dry-ice blasting also let me see that my rubber steering boots were torn. I had not seen that in the years leading up to this point. You can see the tears in the pic above.
So THAT led me to replacing those too. It really does help go through the car thoroughly.... & for me, especially during a 20 yr ownership stint, the last thing I want to do with the car is become complacent.
So much fun owning a car that I am very proud of,... not to mention all the memories the car has given us, and the friends we've met over the years. Cobalt knows. Bad Boys Mike knows. Those two guys have really expanded my circle as well. Igooz too!! You guys are awesome, and I thank you all for sharing your stories here too. It helps keep the STOKE alive!!
The following 2 users liked this post by bweSteve:
cobalt (01-31-2024), Igooz (02-01-2024)
Old 02-07-2024, 11:30 PM
  #32
bweSteve
bweSteve's Avatar
This is like looking at Jewelry for me {below pics...} Amazing before and After ...
Originally Posted by cobalt
You can get into one for not much these days. They used to run about $7k on average. All depends on cabinet size. I used one similar to this I have access to 2 and they are all similar. The issue with Vapor honing is they are a high maintenance tool. That is why I prefer to borrow than buy.
​​​​​​https://vaporhoningtechnologies.com/weekend-warrior/ They recently picked this up at the dealership my son works at I used it once and it wasn't bad.
My C2 trailing arms before. Can't believe this was 2021 already.
After.
No change in appearance since. Even after many wet drives.
Old 02-08-2024, 04:23 AM
  #33
peterpullin
peterpullin's Avatar
i went the other route. no dry ice, cleaned by hand. with parts cleaner, brush and water. this way i kept the original factory optics. even the brownish corrosion protection stays in place - only dust, oil, black debris is removed. car looks not as perfect as yours. instead it looks more as no one touched it ever.
Old 02-09-2024, 11:43 AM
  #34
urquattro20Vt
urquattro20Vt's Avatar
Congrats on the purchase - these are amazing cars that have come into their own - perfect combo of old feel but very usable. I hope you put lots of miles on it.
Brandon
'91 Turbo
Old 02-09-2024, 11:53 AM
  #35
Boosted321
Boosted321's Avatar
I can only imagine how the lower valance beam got like this:
But all better now:
Old 02-09-2024, 12:09 PM
  #36
Boosted321
Boosted321's Avatar
Pretty nasty oil leak coming from the rear passengers side oil line fittings:
No more leak(for now🤞&#127995:
Can’t wait to start getting all this oil and grime cleaned off!
The following 3 users liked this post by Boosted321:
cobalt (02-12-2024), heliolps2 (02-09-2024), wicks (04-23-2024)
Old 02-12-2024, 09:27 AM
  #37
cobalt
cobalt's Avatar
Received 2,170 Likes on 1,299 Posts
The oil tank and those hoses are one of the biggest issues and I always keep a spare set for my cars just in case. Another one you should consider replacing is the J tube at the end of the metal pipe in the wheel well. Thirty year old rubber dries out no matter if it is garage kept or not.
Looks like the lower valance beam came loose on the one side and had been dragged across the bottom for a while. Nice clean floor pan considering. I would replace the 5 drain plugs while at it. They keep moisture from getting trapped in the frunk.
Boosted321 (02-12-2024)
Old 02-12-2024, 06:33 PM
  #38
urquattro20Vt
Be sure to use proper hose for that little connector from the tank. It's easy to just throw anything that will fit there - but needs to be rated for the temp if not also pressure. Not a hose you want to fail.
And yeah that J hose like Anthony said - I had one fail once - was only a couple years old - luckily it happened literally just as I parked my car in the garage - dumped out a ton of oil. If that would have happened while driving - bad news.
Brandon
'91 Turbo
Old 02-13-2024, 10:09 AM
  #39
Boosted321
Boosted321's Avatar
Brandon
'91 Turbo
Yes! Those are correct Porsche oem hoses. Thanks for looking out!
Old 02-13-2024, 10:11 AM
  #40
Boosted321
Boosted321's Avatar
Thanks! Will have that replaced as well for peace of mind!
drain plugs ordered too! Keep the suggestions coming!
Old 02-13-2024, 11:50 AM
  #41
spartansix
spartansix's Avatar
What's the part number for that J tube? I'm not sure if I'm looking at the right thing on the parts diagram.
Old 02-13-2024, 01:33 PM
  #42
urquattro20Vt
If you can post up the Turbo oil system diagram I can tell you which part.
Brandon
'91 Turbo
Old 02-13-2024, 05:43 PM
  #43
Boosted321
Boosted321's Avatar
Is this what you are referring to Cobalt?
Old 02-13-2024, 06:48 PM
  #44
spartansix
spartansix's Avatar
Old 02-14-2024, 09:20 AM
  #45
cobalt
cobalt's Avatar
Wow these are $76 from Sunset Porsche. I have a.receipt here from 2 years ago it was only $46. One thing many do is constantly crank down on the worm clamp if they see weeping. Big mistake. That will just cut into the hose and cause it to fail. If your hose starts to weep you can just loosen the clamp and move it on the hose to a fresh section until you get a replacement.
Quick Reply: New to me Forest Green 964T
