Is this my fuel pump (turn on sound)
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
I haven't done any wrenching in a year, I'm sure I knew the answer to this 12-24 months ago. Hah.
Is this my front fuel pump screaming? Intermittent, but screams sometimes with ignition switch on, for 5 seconds - 30 seconds.
(Wait for second ignition switch on, why Vimeo won't let me trim this grr.
Gosh should I use an OEM unit for $730 (EACH SIDE) or the Dansk for $215?
https://www.sunsetporscheparts.com/o...er-96562415100
https://www.autohausaz.com/pn/965624...rm=96562415100
sounds like a tesla on streoids
no fuelpump. +1 for blower
Wicks,
The fan should only come on when you have the heater switched on and turned to red. Sometimes the relays get stuck on all the time even with e heat turned off, which means you have been running the **** out of the blower motor and may have caused it to overheat and go bad. Just a thought my friend.
Helio
Helio
Oh crazy, well the engine always runs super cool even on hot days. I thought these fans were also engine temp controlled as in they will also run just if the engine temp gets up to levels.
How to jump these? Hah. Have the relays off and jumping from side to side and every which way can't get the fans to fire up.
I believe this is the relay info you need, You may need to turbo the key to the on position.
![](https://ww2.justanswer.com/uploads/bkitchener/2012-02-19_050430_fuel_pump_relay.png)
