Fuel Accumulator Bad?
Well after fixing way too many things I care to remember it seems I may have a bad fuel accumulator. The car takes a few cranks to start up when it's cold but it does start every time. Doesn't feel like it starts on all cylinders though as it cranks and then slowly comes to life. Once alive, no issues at all. But after driving and parking and then restarting it takes a long time to catch. I thought I was going to be stranded to be honest but it came to life and worked. After parking the car it smelled of gas but there were no leaks. Was going to replace the fuel accumulator but I don't know about the gas smell and if the cold start sequence is a problem. Advice?
It is the fuel accumulator 1000%
Has happened to me before, Your mechanic can test the system and watch the pressure as the minimum indicator is 1.4 bar after 20 minutes.
Agreed bad accum, had to do mine too last year, the rubber in them just doesn't last more than 25 years. It's behind the filter on left on engine bay, takes some crafty wrenching to replace. There are numerous instructions, just google.
Unless it’s ever been done - I’d also suggest either get the injectors cleaned by a pro or replace them. My car had a slight hard start (needed a little pedal on cold starts) before the engine rebuild and we had a local shop test and clean them. One was leaking and bad so it got replaced. The rest were fine and the cleaning got them more equal and a better pattern. Now it starts as it should.
Well it has to go in but not all that happy. Motor was out not too long ago and none of this was done and I think it should have been done. Looking through receipts seems like the fuel filter was replaced but not the accumulator.
I did mine when the motor was out - so it was easier. Getting the two fuel lines lined up so they’d thread onto the accumulator was a small pain if I recall correctly. Are you doing the fuel filter too? Going off memory of how much space you’ll have to work with - wondering if it’ll help to remove the rubber intake elbow...?
Fuel filter was just replaced. I don't get why they wouldn't replace the accumulator. The issue I see is getting the 2 lines behind the accumulator off and back on. Very little room even with the intercooler off. May bring this in because I am dealing with fuel and the last thing I need is to dump a bunch all over my garage. Again!
