OEM RS Short Shifter problem
Thank You
So I am having a Porsche RS short shift being installed on my 92 Carrera 2. The problem is that it's hanging below the bottom plate. Does this have to be modified? Or is there something overlooked on the install? Bought the kit from ECS Tuning.
You need to flip these bushings over so the hole is on top.
I see your car is a 92 so you should have the bushing pictured. Early cars like mine, have a round bushings and the holes need to be opened up to fit the oval ones.
Thank You
The RS shifter pivot point is higher up on the shift lever, therefore the shifter moves everything downward relative to the shift tube location. Hence why you need to flip the orientation of those oval bushings in order to raise the shift tube and bring everything back in line (i.e. clear the tunnel cover).
You're lucky that your car isn't a 91 or older where instead of having an oval hole from the factory, you have a round hole that needs to be drilled upward to fit the newer oval bushing. Doing that job while laying on your back under the car is a bunch of suck.
Thank You
Super easy job if your car is late model with the oval shift tube bushings.
If you have a car with round shift tube bushings, then you have to drill and/or grind the shifter box in the tunnel to accept the later bushings. That's a pain.
Someone on here had a metal template they were loaning out that should make the job a lot less nerve racking. I didn't borrow it. I just did some measuring and made a template on cardboard using the oval bushings and it worked out fine.
You gotta get the car up really high to be able to work effectively down there. Still a beat down.
I've heard the OE plastic ball cups are super hard to snap into place. I used all FD Motorsport components with spherical ends so I didn't have to mess with those ball cups. The E-clips on the assembly can get fiddly too.
Not hard re 1990 car - search RS shifter install (simple hole saw and file, touch up with rust inhibitor/paint, use jack to pop cup back on (remember ball cup is 944 part i.e. way cheaper; or just weld a rose joint on instead - even better ala Rothsport golden rod)
BUT Beware!
Once you cut the body for the first time ...
and it works ...
oh so well..
and it improves things as much as a short shift does ..
a whole world of options will open to your fragile eggshell mind!
Prepare yourself for #964wesome
BUT Beware!
and it works ...
oh so well..
