Wheel question?
Wheel question?
Hello all
I'm slowly stransform my 964. A local guy have a set of cup wheels that he's selling. Before I pull the trigger just want to check if they will fit on the 964. Here are the specs
235 x 55 R 17 - Rear (52mm off set) and 225 x 45 R 17 Front (45mm off set) 5 x 130 mm bolt pattern
My car is a 1989 C4. Thanks
Hello all
They will work but not ideal. The usual upgrade over the stock 7" ET55 is to put the 8 ET55 up front which will push the wheel out by 13mm. The 7.5 you are discussing will push the wheel out 16mm. How much of an impact will the extra 3mm make is dependent on tire size and suspension setup.
I am not sure why you want to go with an aftermarket 7.5 upfront and an 8 in the rear. If anything most people are looking for 7 & 9's running a 225/255 setup. I am not sure what a 205 stretched on 7.5 and a 255 on an 8 in the rear will do for handling.
I would make sure the wheels are straight and true. Most used wheels are not. if they are all aftermarket they aren't worth much and are usually far heavier than the stock wheels. I hope they are cheap because they will be a hard sell in the future if you don't like them.
If you are looking for a perfect set of factory 7 & 8 or 7 & 9's I will be having a set of each with period correct NLA crested center caps for sale soon but they are not inexpensive but less than new.
Talking about tail happy. My 90 C2 Targa came from the PO with 7.5J (ET 26 or 76 can't read it properly) and 9J (ET47). I'm running 205s and 255s with that. I ran it off the road backwards (no injuries or 3rd parties). My driving’s pretty average at best, but could my rim/tyre combination have contributed?
Another concern is tire choice, condition, age and temps that can all play a factor in changing handling characteristics.
Be careful it takes time to learn these cars if you are a novice at driving them. I can't tell you how many friends over the years with considerable driving experience couldn't get a 911 to move without stalling them and at one point early on found a way to get the tail to slip out on them. If you think these can be a little crazy try an old long nose.
My .02 worth. Take it to an autocross event and have some fun with it. You don't have to win or even place just go out and learn to drive it at its limits in a controlled safe setting. We offer Car Control and AX schools for our PCA region members to do just this. I love it when I instruct a new older 911 owner and they are amazed at what these cars are capable of doing.
Thanks cobalt. I've booked a day on a test track with an instructor for this very reason. The OP’s post and some of the answers just got me wondering whether my rim/tyre combination was not helping. 255 seems widely used on 9Js, but 205s on a 7.5J is not a combo I see regularly on these posts. And you're both right, I went into that corner too fast and lifted off. Rookie error some of us learn the hard way I suppose...
Good Luck.
