master warning light .... HELP
It does lit when the key is in 2 position (suppose all dash lights should on anyway ) and the engine off.
when the engine is fired up and it goes away immediately, even when the parking brake has not been released.
Tried to remove the connection of the fan belt sensor to trigger it, it doesn't lit.
I'm sure the bulb itself is fine , but any clue or direction for me to follow up?
thanks!
Does your park brake warning light ignite when you activate the brake handle? If not, I guess you have a faulty park brake switch. It is known to become detached in the brake handle mechanism.
As far as I remember is the belt warning switch a normally open switch. Disconnecting it will not trigger any warning. Closing the switch (or shorting the two terminals in the switch connector) will trigger the warning. Be sure to keep the switch closed for some time before the warning starts.
Cheers,
Tore
additional info,
the bulb in the cancel warning button is always on , is it normal?
Cheers,
Tore
