My biggest fear was removing the exhaust, It came off very easy, surprisingly. Everything has been sent off, Now I'm just waiting things to get back. and parts from the Porsche dealer to arrive. I decided to use all Porsche dealer parts, My local dealer gives me a deal on parts,
It all started with a simple valve adjustment...lol
THEN.... 1. A clutch refresh with a Porsche OE 3.6 turbo pressure plate, Porsche OE Disc, Porsche OE TB, keeping the DMF, just clean t up a little. 2. New Injector blocks and gaskets, they looked good until I pulled the the manifold off, wtf, they were all cracked. Surprising she ran fine. Hmmm 3. I did a little cleaning wasn't to bad, but the out come was great. 4, I'm having the fan and fan shroud blasted and ceramic refinished. Ceracoat 5. Since I'm here, I'm having all the exhaust pieces ceramic coated, including the spider tube and replacing all the hardware with new and gaskets. 6. I sent off all my other hardware to California Van Nuys Plating for re plating in yellow zinc, pulleys, strap, bolt nuts washers,,ext 7. Porsche OE Cap and rotor, and oil and fuel filter. removed the K&N filter. replaced with Porsche OE air filter 8. New Porsche OE Bosch plugs 9. Valve Adjustment, New silicon valve cover gaskets. My first time doing it . Very simple with the engine out and the exhaust out of the way. I used the Kirk tool. 10. Refinishing the wastegate and turbo hot housing in Factory gray ceramic high coating. Installed NEW RUF wastegate spring 11. Having the valve covers glass bead blasted. I used a high temp clear and kept it natural alum 12 Replace the engine carrier with a new one. 13. Having some other pieces powder coated. 14. I'm also did the front suspension, Blasting the L arms and the A arms and replacing ball joints. and having the hardware re plated as well..
My biggest fear was removing the exhaust, It came off very easy, surprisingly. Everything has been sent off, Now I'm just waiting things to get back. and parts from the Porsche dealer to arrive. I decided to use all Porsche dealer parts, My local dealer gives me a deal on parts, Just some updates on where I'm at on my project
The diaphragm looks great, no tears, just a little dirty, From what I can tell the spring looks to be stock, surprising clean, Spring Length = 7.0 inch Outer diameter = 2.70 inch, Number of effective coils = 5.5, Wire diameter = 0.196 inch. I ordered a RUF 0.9 bar spring. I don't trust the manual boost controller. does any have a RUF spring in their 965. if yes what's your thoughts.
I had my AC converted to A134r in May of 2017, at my local Porsche dealer and it worked really well. I think the coldest it got at the vent was 36 deg, Not bad! until I went to test it last month, just after my winter project was complete. The compressor kicked on but no cold air. I had a local Porsche shop Autobahn Porsche service in Fairfax VA recharge the system, I was not aware that the 964 C2 took 850 grams and the 965 took 1020 grams of refrigerant, I didn't think there was much of a difference between the two cars AC system. Maybe someone here can chime in and can tell us why the difference. Anyway, I did not change the dryer, It's in the plan for next year along with the expansion valve, or maybe I don't have to. Your thoughts?
The charge lasted 4 years, is that about normal ? I just got back from a drive, it was in the low 80's out and I got to use the AC and it's cold, I saw temps as low as 32deg at idle in the garage. Here are some pics. I'm proud to tell my friends that my AC is ICE cold, Not what you would normally see in air-cooled 911's ..lol
Here's my hack that should improve my AC temps. My HVAC seems to work fine. My center and side vents temperatures in the summer are in the mid 30's which is really good and everything works as it should. I had the CCU rebuilt by ECU Doctors a few years ago and other servos work as they should. I also changed both the resistors at the blowers at the rear and the heat sensor in the rear engine compartment, The 964 turbo has two blowers in the rear. The Hammer shows no issues.
It seems to me that hot air is leaking past the foam seals on the flaps and the plastic elbow that connects the suitcase in the footwell. See the foam is old and falling apart and If either one fails you have hot air mixing into the cab or into the suitcase/vents. The interesting thing is my brothers 993 blows a little bit colder and he lives in AZ. Which got me thinking why, The 993 flap uses a rubber seal in its flaps to close off the hot air from the cab sealing it completely. 100% seal. My fix is a hack, I put 993 flaps on each side of the footwell paper tubes and I close and open them manually during the summer months. Blocking the heat from entering the suitcase and the cab. This hack lowers your vent and cab temps a lot. I'm using all 993 Porsche parts and easily reversible. Your thoughts on the mod.
Please let me share my 2021-2022 Winter projects, completed Welded jack point left front.
Replace left side finder lining due to crack. Porsche Part Replace all fasteners in all the fender liners and under panels, Porsche parts Replace AC ribbed pulley, Porsche Part Replace main oil line and hose and clamps, Porsche parts Completed oil change Porsche filter and Driven 15/50 oil Replaced heat tube to the suitcase, Porsche part Modification and installation of 993 heater valves and hoses. Porsche parts Re-applied Ammo ceramic coating on paint, wheels, brake calipers, and fender liners.
I'm ready to enjoy the 2022 driving season. Thank you for following my thread.
