964 Forum 1989-1994
Locating Wing Mirror switch under dash
Old Oct 5, 2003 | 05:05 PM
Kahdmus's Avatar
Kahdmus
Default Locating Wing Mirror switch under dash
I am trying to locate the switch under the dash that relates to my electric wing mirrors. Adrian had suggested that it was under the main cluster, slightly to the left. Still unable to locate the switch in question I took these shots of the immediate area in the hope someone could possibly give a more precise guide:
Thanks!
--Kahd.
Old Oct 5, 2003 | 05:28 PM
John Boggiano's Avatar
John Boggiano
Lifetime Member
No, Howard -
It's on the bottom of the instrument cowling.
Old Oct 5, 2003 | 05:31 PM
John Boggiano
Lifetime Member
Here...
Old Oct 5, 2003 | 05:32 PM
Wikkid911's Avatar
Wikkid911
Remarkable
Kahdmus,
When he said under the dash he meant under the clocks. From the pictures you took you have literally gone under the dashboard! Go back to the instrument clusters and its just underneath them, no more than 2 or 3 inches from them.
Cheers
EDIT: Just looked and while I was typing JB posted the above pic. Try that first and if you get stuck see my post.
Old Oct 5, 2003 | 07:58 PM
Kahdmus's Avatar
Kahdmus
I know where the selector switch is on the dash! I didnt think he could be suggesting that. I was thinking he meant a connection from the switch that was loose UNDER the dash - I guess I shouldnt have used the word 'switch!' Anyone have any ideas where there could be a loose connection?
Sorry for the badly worded post and subsequent confusion! :-(
--H.
Old Oct 6, 2003 | 03:10 AM
John Boggiano
Lifetime Member
--H.
How disappointing!
We were all looking forward to telling you how to find your handbrake, steering wheel, etc.!
Old Oct 6, 2003 | 03:44 AM
Adrian's Avatar
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Dear H,
There is only one switch, the selector switch which allows you to select right or left mirriors to adjust.
Then you have the adjuster on the door at the top. That is it the rest is just wiring.
You are more than likely going to have to pull off the door trim. More than likely you are going to find a pulled connector or wire. 99 out of 100 times, problems with units in the door or mounted around the door are caused by problems inside the door.
Ciao,
Adrian
964C4
Old Oct 6, 2003 | 06:38 AM
Ade - C4 91's Avatar
Ade - C4 91
Originally posted by John Boggiano
How disappointing!
Yes - very disapointing - where's Christer when you need him.
Old Oct 6, 2003 | 12:51 PM
Kahdmus's Avatar
Kahdmus
How disappointing!
Well sometimes John the reminder would come in quite useful, so feel free...especially on days like today!
Cheers,
--H
P.S I'll print it out and leave a copy in the glovebox, just in case!
Old Oct 6, 2003 | 08:23 PM
Kahdmus's Avatar
Kahdmus
Mirrors back on........now passenger window not working! Yes - I can find the switch!!! :-)
--H
Old Oct 7, 2003 | 01:05 AM
Ruairidh's Avatar
Ruairidh
Super Guru
Here...
John, Tsk Tsk I see specks of dust on your pedals. Time to get polishing!
Old Oct 7, 2003 | 11:30 AM
warmfuzzies's Avatar
warmfuzzies
John
Have you got new carpets in there, it looks exceedingly clean.....
kevin
Old Oct 7, 2003 | 01:24 PM
John Boggiano
Lifetime Member
Yes, that was taken pretty much as the car came home from having them fitted, I think.
Needless to say, R, the dust has since been removed!
