front splitters
front splitters
Wanting to get a front splitter or lip for my car but from reading on here there's some variation in each of them. My setup is already different as I have a fixed wing on the back and it definitely catches some air at all speeds. Looking for recommends so I can move on this before long.
Agent Orange
I had TechArt on my previous 2 964s. Great quality, easy install, but they are impossible to find these days. I even spoke with the guys at TechArt at Rennsport about making new batches of parts for 964s and 993s but they said that the production process is too costly and once made the product won't move quickly enough to justify the expense.
Which leaves us with Cult Werk. Those guys are top notch! I've ordered several body pieces from them for the 964 and the quality is OEM-like. Their splitters are really well made and fit perfectly. The only thing to note is that the rivets they use are really heavy duty so be ready for some hard squeezing!
Here's what they look like on my car:
+1 I ordered a few things from them based on Ilko and Cobalt feedback. I got them and test fit the other day, the fitment is SPOT on. Really nice. I'm going to spray mine with 'trim black' but they don't really need to be painted.
Ruf also has a full lip that looks nice. Getty has a couple different lip options that are more aggressive.
I think for your car the Ruf lip or the cult werks RS spoilers would look nice.
There was one in the pelican classifieds yesterday for cheap:
http://forums.pelicanparts.com/porsc...-splitter.html
Definitely a great price. have thought of these and wonder if the side wings would make it too aggressive. The cult werk ones look great but not sure if aggressive enough with the bigger fixed wing. At highway speeds you can feel a difference in handling unless the wind is behind you.
You should be fine with balance.
Are the Cult Werks Splitters functional at speed or just for appearance purposes?
Well, i have not run them on my car, given that theoretically they're not too different than the change from the OEM spoiler to the cup car spoiler on my 997RS and that they are modeled after the spoiler used on the 964 RSR, I think they would be functional. Of course at speed.
The cult werks ones are identical to the factory turbo S splitters also used on the 3.8RS. They were matched for the turbo S tail you have which is one of the largest single piece wings used on a Porsche.
I have them on my turbo (factory pieces) and on my track car CF from Getty Design. They make a considerable difference at high speeds with both the turbo wing and the bi-wing. I also have the techart splitter on my C2 with an RSA rear wing.
IIRC the concept is the splitter reduces front end turbulence and creates a negative pressure in the center which actually sucks the front of the car down at speed.
These really only make a difference at speeds above 120mph which you can feel on track anything larger might be overkill but most of these are usually added for cosmetics.
The Getty design are not as large and seem to be less effective at speed. I am considering going with a larger front wing type with the cunard's on the sides like Justin posted, since i hit speeds of over 150mph and these become less effective at speeds approaching 140 or more. Of course all of this has to do with stance and other factors.
So if I'm using the stock rear spoiler would you recommend not using the cult werks spitter? I occasionally do DE at a high speed track where you reach 140+ on the front straight into a fast banked corner. Turn two is a long sweeper that you can take at 110-120 but the rear end gets very light if you're not on the gas. Would the cult werks splitter generate too much down force on the front, making rear too light? Ideally I'd probably go with something like a 3.8 RS rear wing but I'm not sure I want to make that modification.
I would consider an RSA style wing before I did the front splitters. Although a proper balance is best and having both works much better than one or the other.
Must be a hell of a track. most around here like the Glen and VIR the most you can hit in a C2 is top of 4th or 138 mph.
The track is BIR (Brainerd Intl). It has a mile long straight that is also used for their NHRA dragstrip. My 964 C2 will redline in 4th about 2/3 - 3/4 down the main straight. The fast drivers (not me) can keep their foot on the gas going into the banked corner. I've been a passenger in GT3s and a GT2 on this track and their speeds are amazing.
Agent Orange
You can hit 140mph in a 964 on the Nascar portion of Pocono North. I've always found the front end of a RWD 964 to be more floaty at high speeds. An RSA wing would work well with the splitters if you're looking for more downforce.
