rear trailing arm clearance
Hi guys
What's everyone's idea on how much clearance there should be from the rim to the trailing arm..not a great picture but it does not touch the arm in its current position with a 6 mm spacer. If 6mm is fine I might just be able to get away from having to get extended wheel studs.
The wheels are 10.5 inch wide..I don't have tires sorted but will be 265's so I suspect that the tire should not really sit outside of the rim.
I need to run the minimum amount of spacer possible to keep the wheels from moving out past the guards anymore than they have to. I will have to roll the guards /lips to give a bit more clearance..
The wheels I really wanted (speedlines) are rediculously priced, and with the copy wheels just don't seem to look right in my eyes.
These techart wheels are only available in a 10.5 inch rear so will have to make them fit..
The picture I posted is with a 6 mm spacer...with a 6 mm spacer I might just be able to get away from having to change to longer wheel studs. Any wider and I won't get enough turns on the nuts.
