vacuum lines for fuel induction
Having some issues as to where some vacuum lines are supposed to go. Changed out my fuel pressure regulator and now I cant seem to get the crank easily. also I have seen a three way and four way connector listed but only have a three way towards the front of the intake on mine. if anyone could point me in the right direction it would be greatly appreciated.
I'll be chasing vacuum leaks later in the year. So I hope someone gives you good advice here that I can follow!
In the meantime...have you looked through the diagrams in the parts catalog? Those are the only way I have ever been able to tell what goes where...
If i ever get it figured out I will put some picks on Goughary. the only prob with the diagrams is that they really dont tell you where the lines go from the diagram if you know what i mean.
the throttle body would be a good start. I have the plastic housing and the only thing I can tell from the diagrams is the idle vacum line at rear connects to the Y connector. then bottom of plastic body to the Y and then into the airbox. Where does the throttle body metal nipple connect? Looks like line/part 32 on diagram 107-02.
