Motor Oil suggestions for 964
EDIT:
http://www.bradfordtoday.com/2014/10.../#.VeoKrZeYE8I
Looks like the brand is being sold, but ARG will continue to produce the product for new distribution company.
Former Vendor
Charles Navarro and I found Brad Penn and brought it back to the aircooled world in 2002. I used it exclusively for years, and did a ton of development for ARG. They would have us man their booth at PRI and etc, and then all of a sudden, around 2009 it changed. They never even bothered telling us, and I found the differences through how the oil smelled, and the color, along with the power that it made. UOA confirmed that the visq changed, and the TBN slipped.
When that happened, I dropped it like a bad memory.
Small things I noticed after I went from BP to Joe Gibbs DT 50. The engine seems to be crisper/ more eager to rev, and the oil pressure is a little bit higher than it used to be, after everything is warmed up nicely, and the engine definitely runs cooler, so if my oil analysis this fall come back with good numbers, I am sold.
Former Vendor
Your UOA will look better after the next service of DT50, as cross pollination from your previous oil will still be there on this first UOA.
In my 88 Carrera my oil temp dropped 20Fwith DT50 vs Brad Penn when running AC in the hot summer.
Former Vendor
When swapping oils to DT series, I always run a BR oil for 1-300 miles to flush the system, then I go to the new oil and results are better straight away.
Definitely could have been my issue as most say that temps are better. My engine is being rebuilt and I have replaced the oil cooler, so initial break in oil will not be mixed.
Everyone's got an opinion on this . I can share the what and why which may help.
I run Mobile 1 15w-50
I run this for a few specific reasons which may or may not be valid:
- Higher Zinc and Phor counts than other Mobile 1 products https://mobiloil.com/~/media/amer/us...pecs-guide.pdf
- My 964 is a daily driver and goes on trips. M1 is available in many stores nationwide and easy to find.
- M1 15w-50 was recommended by the M1 engineers when I talked with them at a track day
- 15w-50 is a reasonable viscosity for my location here in TX.
Former Vendor
I haven't been an M1 fan since the 90s. Once the formulations changed, and the focus went to keeping "engines cleaner", I was pretty much done. The only product today that I would consider from the M1 family is their V Twin oil, which still has the closest formulation to that of the old stuff.
The 15W50 is probably the best M1 offering for these engines for someone who does wish to use the M1 family.
The only good thing I have found through all our oil development, often using M1 as the control (enemy) is the fuel economy that it gives.
This debate will go on forever, because it takes decades to collect enough data to prove whats best, and why. Few people pay enough attention to the small things to make an educated analysis, anyway. Our Porsche engines are so well built, that most any oil will keep them alive for a long, long time.
