964 Forum 1989-1994
Intake distributor dismantle after start
Old Aug 20, 2015 | 09:10 PM
clali's Avatar
clali
2nd Gear
Default Intake distributor dismantle after start
Hello
Last night my wife started the Porsche 964 1990.
After a big pow;
1-A small amount of smoke
2- no oil on the ground
3-an intake distributor dismantle! See picture
Those somebodies have experience with the cause of this disaster
The somebody has an idea of the repair?
FYI, I was planning to change the rotor and spark plug next week
Thanks for your Help
clali
File Type: jpg
Old Aug 20, 2015 | 10:57 PM
Vandit's Avatar
Vandit
Possibly a leaky injector or failing fuel pressure regulator diaphragm.
Old Aug 21, 2015 | 04:30 AM
tdiquattro's Avatar
tdiquattro
may be talking rubbish but - dizzy belt snapped and backfire through intake?
Or it just came loose over time, but looks like there must have been some pressure to pop all those rubbers off.
Old Aug 21, 2015 | 05:29 AM
alexjc4's Avatar
alexjc4
Yes that has backfired through the inlet manifold. Fuel system issue seems likely.
Old Aug 21, 2015 | 11:23 AM
Vandit's Avatar
Vandit
Broken 2nd distributor belt seems plausible too. Check that.
Old Aug 21, 2015 | 01:48 PM
Robbrizzle's Avatar
Robbrizzle
I've had a snapped dizzy belt do this but I've also had a clogged ISV do similar. Both as as a result of a backfire.
Loosen the large jubilee clips round the throttle body to get the intake plenums back together then check both.
On mine, the ISV needed both a flush with carb cleaner internally and contact cleaner on the electrical connections, I also replaced the crimped clips on the hoses with jubilee clips and so far so good.
Old Aug 25, 2015 | 12:41 AM
clali's Avatar
clali
2nd Gear
Thanks foryour Help
I have reassemblethe air inlet intake plenums
The first think I checked was the 2nd distributor belt.
Yes it was effectively broke.
By the sametime I try to check fuel pressure regulator diaphragm, but I didn’t really know how or what to check on this difficult part to reach.
I did notcheck the ISV yet.
I have readother post regarding distributor belt snap and one of them was mentioning that problemmay have also damaged a cylinder or two...
Is there any simple way to verify this potential problem?
I plant to start the motor (once only) with only one active cap distributor .Is there any contraindicationto do this ?
Again thanks a lot for your comments it is really helpful
Old Aug 25, 2015 | 01:00 AM
Vandit's Avatar
Vandit
For the FPR, follow the vacuum line from the FPR to the center of the intake plenum. Be sure that this line is easily removable at the plenum. Now turn on your car. Once the car is running, disconnect the vacuum line at the plenum and watch it for a minute or two and see if it spits out gasoline through the line. If it does, then the FPR is on its way out.
