964 Forum 1989-1994
spring plates
Old Aug 17, 2015 | 01:44 PM
C4inLA's Avatar
C4inLA
Default spring plates
Trying to educate myself on function and failure signs of spring plates. Web searches & ytube not helping so much ...
View under my car ;
File Type: png
File Type: png
Old Aug 17, 2015 | 02:35 PM
Vandit's Avatar
Vandit
Usually the rubber bush and bellow on the unibody side is torn up.
Old Aug 17, 2015 | 02:51 PM
C4inLA's Avatar
C4inLA
What driving symptom tells you to check spring plates?
Old Aug 17, 2015 | 02:53 PM
Goughary's Avatar
Goughary
When the spring plates get old the rear of the car effectively steers on its own. It's subtle on the street...but you'll know when things start feeling loose back there...you only have three points of attachment to the car, and they all need to be tight...
Old Aug 17, 2015 | 03:16 PM
ThomasC2's Avatar
ThomasC2
The bushing that wears out is not in the pictures, it is on the other end of the springplate. What you se in the pics are the adjustment nuts for camber and toe.
