Transmission fill plug stripped...any suggestions
Hey Guys
I went to change the oil in my transmission the other day and the fill plug is stripped. I can't get the allen key to catch at all. Any tips on how to get this out now? (I've already ordered new plugs).
Can you tap it loose with a cold chisel? I used that method with the seat bolts. Worked perfect.
It's pretty wide, so you have some options, and easy out may work on it.
Also a torx bit might fit in there with some tapping and hold it enough to loosen it.
An old trick to be used with a Torx or Allen, is to dip the end in some oil, then in some sand. The ssand takes up the slack. It worked for me on a stripped steering rack bolt.
