Brass shift rod coupler bushings, cheap golden rod alternative?
C2 and C4 have different ends on the shift rod
http://www.design911.co.uk/fu/prod12...d-96442401908/
If you click on "zoom in" you can see the photo is the C2 part but image in the parts diagram is of a C4 rod.
I think therefore the above bushing is for C2 only.
I wouldn't bother. Brass is a relatively soft metal if it were made from Bearing Bronze than it would be worth it. I suspect this will feel great initially but eventually wear out.
