Brass shift rod coupler bushings, cheap golden rod alternative?
Last weekend I took a friends shift assembly apart to install an RS short shifter and all new bushings. I noticed the rubber bushings in the shift rod coupler were pretty worn and had a lot of slop. I started looking for replacements and found a bunch of poly options, but then I stumbled upon brass ones, they're listed for 65-88, but look exactly like the 964 part, so I figured for $46 shipped, I'd give them a try.
They pressed right in like the originals and work like a champ. It's a night and day difference in the feel of the shifter, there's no more slop at all. Next weekend I do my car.
Anyone else using these?
http://www.ebay.com/itm/Porsche-911-...68dee6&vxp=mtr
If you read through robt964's rebuild thread, I believe he came up w/ a DIY solution using spherical joints.
https://rennlist.com/forums/964-foru...-refurb-6.html
https://rennlist.com/forums/964-foru...refurb-15.html
C2 and C4 have different ends on the shift rod
http://www.design911.co.uk/fu/prod12...d-96442401908/
If you click on "zoom in" you can see the photo is the C2 part but image in the parts diagram is of a C4 rod.
I think therefore the above bushing is for C2 only.
