RS swaybars or H&R swaybars for my C2
Well, I've searched the forum but can't get a clear answer.
Looking at getting sways but is either one better than the other?!?! I know the H&R are beefier.
Also for my C2, I read it's not a direct fitment like the H&R sways..... What's needed to make the RS sways to work.
TIA,
John
TIA,
John
That Is what I meant to say.
Sorry for the confusion
Cup and RS are the same, 24 mm front and 18 rear. Front is adjustable in 5 settings and rear in 3. I think the RS/cup sways is better for a C2 to reduce oversteer and get more rear traction. The H&R are 24 front and 26 in the rear and is probably better for a C4 were you want ot reduce understeer. On a C2 it doesn't sound right to me and I think Porsche did some thinking about this.
With that said, a lot fo people are happy with the H&R sways, so as often it is a question of religion. The Porsche sways are also more expensive.
You need to replace the sway bushings since the sways are thicker. In the front you need the RS Drop links. In the rear I suggest you replace the (now by age sloppy) droplinks with new one's or even better, the solid cup replicas from Rennline.
Thomas
Thomas
My decision making process was that the RS bars had been designed to work with the much stiffer springs on the RS and therefore were not necessarily a direct bolt on solution for a softer sprung C2. Hence I went for the H&R bars. My experience is that they significantly reduce the roll compared to my previous standard bars. Very happy with what they have done.
had both. Now, i`ve H&R in front and RS in the rear. With the quite stiff RS-Springs & H&R sway in the rear, my C4 oversteered..
With proper track focused spring-setup, RS is the way to go. To "improve" a too soft spring-setting and make a C4 feel more agil, H&R sway are usable...
For a C4: on the front, you can`t use all the whole adjustment range of the rs-sway, so you could save the money for the RS in the front and use the cheaper H&R sway (24 instead of 25mm).
Correct me if I am wrong, but the way I see it, a sway bar should be designated by its torsional strength rather than diameter. Is there a way to obtain that information from the manufacture, would be interesting to see.
Also on a C4 you need to run it at the harder setting to avoid rubbing on the front driveshafts
They are a massive upgrade on the standard set
Tdiquattro: The stock sways for both C2&4 is 20 mm, front and rear. Except for C2 MY90 that had a 21 mm rear bar. So a cheap first step for a C4 is to mount this 21 mm in the rear to achive little more oversteer.
