964 Forum 1989-1994
possible weight for a C4
Old Dec 4, 2014 | 04:45 PM
  #46
breljohn's Avatar
breljohn
How easy is it to find these parts? And the install?
Anyone knows?
Originally Posted by 911Jetta
Or switch to a lighter C4 system from the 993? Save 50 KG, and keep 4-wheel drive!
From this thread: 9m 964C4 project car - 9m64RS Lightweight the likely outcome?
Post #123
Old Dec 10, 2014 | 04:48 AM
  #47
koenig_roland's Avatar
koenig_roland
header is in place
Old Dec 10, 2014 | 05:32 PM
  #48
kos11-12's Avatar
kos11-12
Sounds really nice !
Regarding weight saving, I just purchase a lithium battery to replace my Odyssey PC 680, 16amp, 170 cca , 7kg.
It's a LifePo4 32 amp with 420 cca, weighting 1,6 kg , saving about 5,5 kg.
Old Dec 10, 2014 | 05:37 PM
  #49
Captain Ahab Jr.'s Avatar
Captain Ahab Jr.
can you post a link, that is some saving over the standard Bosch battery
Old Dec 10, 2014 | 05:57 PM
  #50
kos11-12's Avatar
kos11-12
http://www.ebay.fr/itm/BATTERIE-MOTO...3D171547482677
I hope you can open the link , let me know
270 € I though it's not bad for what it is ....
Old Dec 11, 2014 | 12:29 AM
  #51
HiWind's Avatar
HiWind
Nice ... Shd last 8-10 yrs too so not really as expensive as it appears vs. a lead-acid which lasts 3-4
Old Dec 11, 2014 | 05:15 AM
  #52
robt964's Avatar
robt964
Not up on my battery tech so much, so how safe are these? Are LiPo batteries as much of an incendiary device as I read?
Old Dec 11, 2014 | 05:36 AM
  #53
jack.pe's Avatar
jack.pe
Good work on the car.. I had similar ideas and last time I weighed mine it was 1302KG with 1/4 tank of petrol. The sunroof is now being removed, RS glass fitted and the engine lid being replaced with a Ducktail so that should help more..
https://rennlist.com/forums/964-foru...l#post11538589
I am probably going to go the route of converting to C2.. I will weigh the car before and after so we have a definitive answer as to how much the 4wd system adds.. don't forget that C4s also get a different hydraulic braking system and that may add more weight as well.. plus i believe the front end of the C4 chassis has extra bracing as well. This will all add weight.
Old Dec 15, 2014 | 06:03 PM
  #54
kos11-12's Avatar
kos11-12
Hi Rob , what did you read then ?!
Old Dec 16, 2014 | 09:02 AM
  #55
PorscheDoc's Avatar
PorscheDoc
I can't remember what are weights were off the top of my head, but a customer of mine had a 90 c4 E class race car. 300lb driver and 120lbs of ballast on the floor (including the spare tire in the trunk), and we still couldn't make PCA's minimum weight. 2 scruitineers looked it over closely and couldn't figure out why we were so much lighter than what we should have been. I even diassembled the a/c compressor and filled it with melted lead to try and add weight (can only add so much ballast on the floor, which we were over already anyway).
Old Dec 16, 2014 | 11:43 AM
  #56
KaiB's Avatar
KaiB
The REAL secret is the fact that Al actually only weighs 172#...
Old Dec 17, 2014 | 06:28 PM
  #57
PorscheDoc's Avatar
PorscheDoc
Which half, the upper or the lower?
Old Dec 18, 2014 | 01:58 AM
  #58
HiWind's Avatar
HiWind
Wow headers sound business ... That'll bring a smile per mile!
Doc .... Great blog and lots of neat detail ...thanks!
Old Mar 26, 2017 | 06:32 AM
  #59
koenig_roland
i have an update here:
Got my car back from the workshop (were the unibal conversion was installed). Some additional mods are done in between (GT3 starter-motor, LIFEPO4 battery, and other - smaller stuff). With 1/4 fuel, the car weights 1230kg at the corner balancing scales.... still with steel bonnet/hood.
Quite impressive numbers for me. Next step is carbon rear bonnet (already in my garage) and - perhaps - carbon hood...
Old Mar 26, 2017 | 07:09 PM
  #60
Captain Ahab Jr.
Quite impressive numbers for me too, good effort!
