964 Forum 1989-1994
help question
Old Nov 16, 2014 | 11:49 AM
ray stobbs's Avatar
ray stobbs
Default help question
hi i have started my top end refresh and at the moment i am strugling to get the clutch fork shaft out to split box from engine i have undone the bolt retainer and have inserted a 5mm bolt into the end of the shaft to pull on but no movement at all is this common any help would be apprecitated regards ray
Old Nov 16, 2014 | 12:13 PM
Goughary's Avatar
Goughary
I love how these motors look when they first come out for a rebuild.
Good luck with the project. Don't forget to soda blast the engine tins and have them powder coated (if they aren't too rusted through...
Sorry can't be of help with the issue at hand, but will be watching...
Old Nov 16, 2014 | 12:17 PM
ray stobbs's Avatar
ray stobbs
engine tins to far gone 3 out of five required thanks for the tip
Old Nov 16, 2014 | 02:30 PM
Goughary's Avatar
Goughary
Yeah that's typical, mine were mostly shot too. I bought all new ones, and had those powder coated before putting them back in...
Old Nov 16, 2014 | 03:01 PM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
I had difficulty removing the clutch cross shaft on my cab, the first time I did it. For me, the trick was to put a long 6x1.0 bolt in and then I used a claw hammer claw to pull the shaft out. I used a block of wood to help brace the hammer.
Old Nov 16, 2014 | 03:09 PM
ray stobbs's Avatar
ray stobbs
thanks rob at least am on the right track need to get a longer bolt tomorrow and try again did yours have needle rollers or plastic bushses mines a 91 this is were am at now waiting to go onto engine stand
Old Nov 16, 2014 | 03:14 PM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Yes, my roller bearings were shot. I found a bunch of the rollers in the bottom of the bell housing. I replaced the cross shaft, bearings and throw out arm with new.
By Verdad Gallardo | 2026-04-28 19:00:17
