Adjustable Fuel Pressure Regulator
I am looking for an adjustable fuel pressure regulator for my 964-based race engine. It needs to fit the stock location and plumbing.
What options do I have? What pressure ranges do they support? How well do they work?
Thanks!!
Thanks!!
Does this one work okay?
http://www.lindseyracing.com/LR/Pors.../911-4501.html
From talking with Dave at Lindsey, it adjusts to as low as 30 psi (2 bar) all the way up to 80 or 90 psi (5.5 or 6.2 bar). Stock is about 3.8 bar (55 psi).
^it wouldn't be very accessible given where the FPR resides under the plenum. There is an unused fitting on the bank 1 fuel rail that is better suited for a gauge.
Vandit,
I was thinking the same thing about being accessible but assume you can use a relocate with braided lines. I guess, why bother when its super simple to run it off the fuel rail.
I am wanting to add to my car. Do you have any sort of recommendation for decent guage?
This is the one I've used, it is a one time set and forget item so ongoing access to it really isn't all that critical
https://m.automotion.com/high-perfor...1989-1995.html
One wouldn't want to adjust the fuel pressure without being able to read and adjust the air/fuel mixture. It certainly does not hurt to have a fuel pressure gauge somewhere inline so you know what pressure you are using. But that is not really important compared to the air/fuel ratio.
More importantly than just the fixed pressure is the adjustables are also rising rate regulators. The stock one has some attenuation but are basically limited to one pressure set at low rpm or at power, it is therefore a compromise at either end. The adjustable rising rates allow for a more linear matching between vacuum and power levels as well as a higher ultimate pressure. This makes for better throttle response as well as better A/F matching. They are generally ok out of the box but as winders has said it can be optimized on the dyno with F/A levels.
For sure the FPR location is a challenge in terms of on the fly adjustments, but possibly thinking of using a temporary remote adjuster similar to the ones available in the market for shocks or brake bias.
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/986x480/images_bias_dash_adjuster_455646_adeb857e1e13d1f8d012f8ab19305a3039bbbedf.jpg)
Thanks in advance for your input.
Carlos
Changing the fuel pressure is an awful way to affect the afr. Tune the chip or use an aftermarket system. Fuel pressure changes everything, everywhere. Adjustments are only useful when balancing injector size and duty cycle before tuning everything else.
