964 Forum 1989-1994
Bump steer
Old Oct 13, 2014 | 04:09 PM
vagluv's Avatar
vagluv
Default Bump steer
Should I have bump steer at this height? Should it be able to be adjusted out?
Old Oct 13, 2014 | 06:32 PM
justin-in-athens's Avatar
justin-in-athens
My car is virtually that same height, or perhaps a little lower on koni adjustables. No bump steer.
Old Oct 13, 2014 | 06:58 PM
vagluv's Avatar
vagluv
Any idea what could be adjusted to clear up some bump steer at that height?
Old Oct 13, 2014 | 08:23 PM
crg53's Avatar
crg53
Buy a set of 993 RS aluminum uprights.
Old Oct 13, 2014 | 08:28 PM
Vandit's Avatar
Vandit
Can you run RS wheel carriers on a C4?
Old Oct 13, 2014 | 08:33 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Yes, if you machine them a bit.
Old Oct 13, 2014 | 09:15 PM
vagluv's Avatar
vagluv
I'm actually not so certain that bump steer is my problem. When driving along at highway speeds holding the wheel straight, the car will sort of jump left and right. Really doesn't seem to be related to bumps. It's just unpredictable, but everything in the front end is tight and in good condition.
Old Oct 13, 2014 | 10:01 PM
Jacke2c's Avatar
Jacke2c
Formerly turbotwoshoes
Default Alignment?
Last time aligned? Air pressure in tires? Rear alignment?
Old Oct 13, 2014 | 10:11 PM
Mr.Alex's Avatar
Mr.Alex
How much camber do you have in the rear? When I was around -2.5, the car would wander around on the highway a bit. But now at -2.0 its much better.
Old Oct 13, 2014 | 10:43 PM
lateforlunch's Avatar
lateforlunch
My car felt similar to what you are describing when I learned that my rear spring plates were shot. My car felt very squirmy. Have you given yours a look at all? just a suggestion..
I was on bilsteins and H&R green springs at the time, in case I needed to clarify that.
Old Oct 13, 2014 | 11:08 PM
tbennett017's Avatar
tbennett017
If your car was recently lowered, check that your inboard steering links are installed correctly. If they are off or are at an angle you might have an issue.
Old Oct 13, 2014 | 11:09 PM
vagluv's Avatar
vagluv
for some reason i can't find a record of my last alignment, but it was within the last 3k miles. pressure was just set at 36/40. and I have the alignment settings at work.
Old Oct 13, 2014 | 11:11 PM
vagluv's Avatar
vagluv
i will look into that. thanks
i will look into that too. thanks
I haven't adjusted the height in the time I've owned the car
Old Oct 14, 2014 | 03:47 PM
vagluv's Avatar
vagluv
Ok so the toe clockwise from front left is .22 .21 .12 and .12 camber is -1.43 -1.53 -1.59 and -1.61
anything stand out as a potential problem?
Old Oct 14, 2014 | 04:00 PM
Vandit's Avatar
Vandit
The negative camber can cause the car to follow imperfections in the road. Depending on how wavy the road surface is, it can get busy when behind the wheel.
