964 Forum 1989-1994
C4 planetary gear where???
Old Jun 11, 2015 | 04:08 PM
John McM's Avatar
John McM
Originally Posted by Duck
Anybody have an estimate of the cost to check the planetary gear? Since I have the engine and transmission out for engine rebuild, wondering if I have it checked. Thanks.
I don't have a cost but it will be the cheapest cost ever at that point. I say check it, because otherwise you'll be left wondering and a pin backing out now is so easily fixed but potentially very expensive if if goes, not to mention searching for a planetary gear if it does go.
Old Jun 11, 2015 | 04:27 PM
Duck's Avatar
Duck
Thank you. I will have it checked.
Old Jun 11, 2015 | 05:48 PM
Goughary's Avatar
Goughary
Question for you...what are the symptoms when this happens?
Old Jun 11, 2015 | 05:58 PM
John McM's Avatar
John McM
Mine was caught before it was terminal, but I understand that the front wheels don't function normally when the gear goes, although that may be intermittant depending on whether the pin is stuck out and/or how far it is out. If you have access to the gear it's well worth checking. The peened areas are augmented with a welded spot to keep the pins in. I don't think there is news of any other weakness in this gear so once the pins are sorted you can breathe easy.
File Type: jpg
By Verdad Gallardo | 2026-04-28 19:00:17
