The silly little question thread ...
#1426
Indeed, there needs to be sufficient enough stud length that accomodates passing through the inner wing itself. There is no individual part number for these studs as they are inherent to the bracket part 964 207 025 02. The 'spacer' part is to prevent overtightening and subsequent bracket cracking when the nut is pulled up inside of the wing (horrors of oil leaks at pressure!).
If the studs are damaged and not usable then it's not impossible to machine new ones - just need to be accurate with the spacer gap value.
I bought the car in my signature out of a barn disassembled, motor on the foor, etc. Dropped the motor off at my builder the day I bought it, gave him all the sorted/labeled hardware. They SHOULD be there with him. But if for some reason they're not, I don't want to have to wait to a single extra day to drive the car while we source new ones.
I think I could make this with a stud, a tap, and some aluminum collars I have laying around. I'll let you guys know if Im successful.
EDIT: Wow, and the whole housing is surprisingly cheap on eBay. I figured a couple hundred. More like $80. Might buy one as a last resort for insurance.
#1427
Just need to make sure that the inlet seats for the pipe unions are not pitted and all threads are good. New pipe copper seals a must (don't use the old ones). I refurbished mine carefully following very small leaks around the housing - tightening up the pipe unions any further asks for trouble. Now dry as anything with no leaks with oil at the hottest temps. Worth taking the time...
#1429
#1430
Apologies if sounding confusing. If you have also removed the filter housing drain plug, then the copper seal ring for that (and any other drain plug accross the oil system). If you have also removed the pipe connecting unions from the filter housing there will be the copper seals/washers between them and the housing.
The main oil feed pipes should have that unpitted shiny (ball) seat. Making sure they're not corroded is a check too.
Cheers
Cheers
#1431
IHI KING!
Cheers
Cheers
#1432
Cheers Rob, Yes, I've seen both used, and from OPC too. Wouldn't like to say what any difference is (if any), unless it's sealing characteristics under high temperatures...
#1433
Ah yes of course, I bought a dozen or so crush washers in each size when I started the project, but they were all aluminum. Bought new drain plugs too. Thanks!
#1436
It is available from Porsche. Prices have doubled since a year ago though.
http://www.sunsetporscheparts.com/oe...he/96457533900
99% of the 964's out there are running without it.
#1438
I ordered foam from Porsche, it was "New" Old Stock, and was disintegrating in the packaging. It isn't that great.
I plan to use this, which is far superior. I have the Porsche bits as a pattern, but this is far more substantial in terms of dealing with heat and weather. It's even grey, like the factory foam.
https://www.mcmaster.com/#8647K29
I'll pull the bumper and replace it in the next few months. : )
#1439
Anthony is right on all counts, as usual ! They are numbers 9 and 10 in that link.
Now i do recall that the one piece for the side by the oil cooler lines did come looking a bit worse than the others.
#1440
That's actually not what I was referring to. On the perimeter of the fan housing surface that mates to the perimeter of the oil cooler, there was a thin maybe 5mm x 5mm strip of foam that sits between the surfaces to create a seal.
It can be seen in this picture, although it's deteriorating here as well.
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/OHkAAOSwaB5XvNFx/$_1.JPG?set_id=8800005007
