Walter's PSS10 clicks
Walter's clicks
http://www.total911.com/interview/wa...e-nurburgring/
Total 911 caught with Porsche legend, Walter Röhrl at the Autosport Show to talk about rallying, development driving for Porsche, and Bilstein suspension.
You had new Bilsteins fitted to your 964 RS. As a test driver, how important is suspension setup in the design process of a new racing model?
I would say that it is the most important thing. On a race track, it is relatively easy to make sure that engines are levelled. So, suspension can give you the only advantage.
Look at the other elements of the car; tyres, aero, brakes. There is no point trying to perfect these until the chassis is working properly. The 964 RS, which I regard to be one of the best cars to drive is a great example.
![](http://www.total911.com/wp-content/uploads/2014/01/Walter-Rohrl-driving.jpg)
From the factory it is too hard up front compared to other Porsche models. It has a hard spring and a soft damper. When you change to the BILSTEIN PSS10 kit, you can really make the car drive much better.
When I drive mine on track I run six clicks on the front and nine on the rear. On the road I run ‘three’ front and ‘seven’ rear. Set like that, the car drives perfectly! If you have this car, you should try it!
On PSS10's the adjustments are labeled 1-10, so no guessing like some damper adjustments where you have to count only by the "click" feeling. Which means on track he is one shy of full hard on the rear. Great info though, not far off how I've run mine which sits on harder than stock PSS10 springs.
Jetta, thanks for sharing. I will be fitting new PSS10's this winter along with RS bars. Great info.
Hal, the dials are numbered. The higher the number on PSS10's the stiffer the set-up. I believe he is referring to "clicks" as numbers. So 3 clicks would be number 3 on the dial. The dial clicks when you spin to the next setting.
Walter use's PSS10 on HIS OWN 964RS.
For pure street driving bilstein pss-stuff should be quite perfect. For some more or harder usage, the street coils are far to soft with its spring-rates. Even if you "close" the clicks on the damper, the spring is still so soft and you drive on the oil-cushion...
I just get original RS-springs with 964 cup dampers in front and 964 RS dampers on the rear for my car during winter hibernation. The 964-cup dampers have the same rebound like 993 RS damper - round about 10% less than 964 RS stuff. The cup dampers are said to be less harsh in the front compared to the orig. rs-stuff and far more sensitive in response.
I`ll also remove the h&r sways and switch back to the 90-C2 setup and not to the orig. C4 setup with 18mm in the rear. I`ll also use rubber top-mounts an no monoballs...
regards thilo
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
