Engine cold and warm reaction
Idle should stay roughly correct then try opening the throttle like in the other videos. Any different?
I will try to get a 964 cold/hot video for you over the weekend.
Procedure very clear! It is perfect! The french name for ISV is Actuateur de ralenti. I have already cleaned this part 2 years ago because of instable idle at cold.
Thanks a lot for vids!
I would check the small vacuum lines going to the fuel pressure regulator, the vacuum valve and also the accumulator chamber on the back of the air filter box.
An easy way to check if vacuum is ok. Run the engine and then turn off. Get someone to switch the ignition switch to the 'on' position while you look in the engine bay to see if the resonance valve cycles. If it does then vacuum piping is ok and the fault lies elsewhere.
What do you mean by " resonance valve cycles" : I will hear a noise or see something?
The procedure is : I am at the engine bay, someone on the driver seat cut ignition and then turn back the key to "on" position. Then I check resonance valve cycles...true?
I can do this with a cold engine (no nead to be at service temp)?
This is the view of the valve, small black bottom left next to/underneath the throttle butterfly depending on year built.
http://forums.pelicanparts.com/porsc...-question.html
Please have a look to the first video, before I start the engine, when I turn the key to "on" position you can hear a "clac" before the "beeeep" of my alarm. Is it that noise I must hear?
The only thing you need to establish at this point is that the vacuum system is ok.
Here are some tests and results:
Test 1)
- is the vacuum system ok? How to do : just start the engine to make sure a vacuum is there then the resonance valve should move the next time the ignition is switched on. The resonance valve is a small black actuator operated by a solenoid / vacuum. It is located on the lower inlet crossover but is not visible. You can hear it 'clack' and see the spindle move when stood looking at the engine.
Results:
I made this test using a stethoscope to hear the "clac" noise in the inlet air manifold. I put the stethoscope end on the second (smaller) vertical manifold the one that has the resonance flap in it. I heard clearly the "clac" noise when putting key on the "ON" position. And when moving the key to the off position I heard again the same "clac" and a short "Pfff" like a pressure that is balancing.
-----> IS IT OK for this test N°1)?
Test 2)
- Check Idle Stabilisation Valve. How to do : Once at hot idle just pull the electrical plug Idle should stay roughly correct then try opening the throttle like in the other videos. Any different?
Results:
After pulling the electrical plug of the ISV, idle stayed roughly the same (a little bit lower). I have NOT observed any modification of engine reaction. (I made a video if needed)
-----> IS IT OK for this test N°2)
Did my car succeed in these 2 tests?
Any additional tests to perform?
Thank you
Yes I will go to a specialist for hammer testing as soon as I can.
What kind of results the hammer tool is delivering? I mean, not only the default list... The diagnostic tool is also performing some tests no? But what is tested?
Also possible to test heater servos fans etc
Tou can also run a testloop of the different flaps, valves and injectors.
Thomas
Before I go to my Porsche specialist, I would like to be more educated about the "normal" engine reaction at service temp.
Could a "Friendly 964 stock engine owner" be so nice as to post videos of his engine reactions from the engine bay and from driver seat? I am realy sorry to insist on this crutial point for me, but before doing anything on my car I want to be sure that my car got a problem (or not). That's why, for my comprehension, I need those videos.
So please I need you!
Thank you very much
