me and my 964: an intro
#198
I done with these wheels. I think the issue stems from him buying non Porsche fitment. He had to re drill them. The back spacing is insane. Could park a truck behind them there is so much clearance. There is more brake clearance than on my cup1s in the front!
#199
I think you nailed it. I will have eurotech check them out. Odds are her ground it off though. When they were re drilled for 5x130, he didn't even bother to clearance them for lug nuts. After they were powdercoated he had to take a die grinder to them just to get the lug nuts on.
#200
Sorry to hear about your wheels. Sucks you waited this long just to find out they don't fit. But if you wanted to use these wheels, couldn't you get them re-barreled for proper fitment? Did you ever get the ET measurement? I just can't believe you can't make these fit after all the test fitting they did prior to building these wheels. Just crazy! So what wheels are you going with now? I agree, Brian and the Rotiform guys are great to deal with. You tell them what you're looking for and they give you a bunch of options until you get exactly what you want.
#201
^^ looking for options now.. Rotiform to their credit was very upfront about lead time, but it just won't work for this year. I'm looking for something to run this summer, and i guess build something else for next year.
#202
Sorry to hear dude.... I am biased but rotiform is the best. I've known those guys for years and have always been there for me. Really, they care about what their wheels. Fit finish and most of all if the customers are happy. All these other wheel "companies" are just janky while rotiform is doing it right. Like you said they are just swamped over there and try their best to deliver. Anything custom just takes time. I know you won't be disappointed with rotiform and if you were for any reason they will make it right.
#204
Specs on original RS012 and RS013 are as follows
RS012 7x16 ET23
RS013 8x16 ET11
Assuming you want to run a 16" to 18" conversion with 8.5 and 10 you'll need to add 1.5" barrels in the front and 2" in rear (this will increase the offset and are the "right" sizes for narrow body 964's).
Final Specs
18x8.5 ET41
18x10 ET35
Only way to run this set up is with stretched tires. 215 fronts and 245 rears.
Hope this helps you or anyone in the future.
#205
https://rennlist.com/forums/parts-ma...er-wheels.html
So not to be a total noob, but will these fit? Offset seems so high
#208
So yea, great wheels, but I would multiply their estimate by at least 2.... And I know your pain for waiting on the perfect wheels, I've once waited nearly a year for one set and didn't get what I expected :/
Sorry to hear about your trouble with the RS's, shouldn't be that difficult to get fitment / ET right, especially if its possible to test fit, so definitely sounds rather unprofessional from they guy making them.
#209
^^ sorry to hear about your wait time.
You're right about it not being difficult having had the car in front of him to measure it. That was the whole reason i went with him over anyone else to begin with. I wasn't looking for a stanced car, but something 8/10ths of the way. I figured being there and having the actual car to measure would have yielded the right result.
Still waiting for him to call me back from yesterday to find out when he's coming to get them and refund me
Still looking for a set to use for the summer. I'll just wait until next year to do exactly what i want
#210
Just so you have it here for when you're ready.
The maximum numbers are as follows,
Front 8.5J ET47 225
Rear 10J ET32 265
These wheel numbers and tyres would require aggressive geo & camber settings. Depending on how low you go you will need to flatten or roll arch lips and angle grind the mounting point between the bumper and wing on the front.
I have seen 9J and 11J fitted however this needed stretched tyres (not ideal), flattened oil lines as well as the above mods.
If you have any questions don't hesitate to ask. Between all of us - we know our stuff, after years of experience.
